eGroupware 23.1 on Rocky 8 and 9
Hi I have two test installation of eGroupware 23.1 on Rocky 8 and Rocky 9
On the Rocky 9 install, files, such as .pdf’s, uploaded and linked to items such as infolog entries do not upload. Existing entries transferred from a eGw 21 installation are shown but don’t display.
This fault does not show on the Rocky 8 installation.
Could this be a permissions issue??
Here are some details of the two systems
Rocky 8
Rocky Linux release 8.7 (Green Obsidian)
Linux 4.18.0-425.13.1.el8_7.x86_64
mariadb-server-10.3.35-1
PHP Version 8.1.17
docker-ce-23.0.1-1
egroupware-docker-23.1.20230314-2.1
httpd-2.4.37-51.module+el8
Rocky 9
Rocky Linux release 9.1 (Blue Onyx)
Linux5.14.0-162.22.2.el9_1.x86_64 #1
MariaDB-server-11.0.1-1
PHP Version 8.1.17
docker-ce-23.0.2-1
httpd-2.4.53-7.el9_1.1
Any thoughts most welcome.
Thanks
Ken
I should add that otherwise the Rocky 9 installation appears to be working correctly.
:slight_smile: Ken
We have other customers using Rocky Linux, but I don’t know if it’s 8 or 9.
I remember from the RHEL/CentOS days, that SELinux can be causing exactly the problem you describe. Have you tried switching it off test-wise?
Thank you Ralf,
It was a permissions issue. This time of my own making. Fixed now.
For future readers of this thread the permissions of the /var/lib/egroupware/default/files/sqlfs directory on a Rocky (RHEL) system look like this
ls -al
total 40
drwxr-xr-x. 12 33 tape 106 Apr 4 20:08 .
drwxr-xr-x. 6 33 tape 68 Apr 5 11:06 ..
drwx------. 2 33 tape 4096 Apr 4 20:08 00
drwx------. 2 33 tape 4096 Apr 4 20:08 01
drwx------. 2 33 tape 4096 Apr 4 20:08 02
drwx------. 2 33 tape 4096 Apr 4 20:08 03
drwx------. 2 33 tape 4096 Apr 4 20:08 04
drwx------. 2 33 tape 4096 Apr 4 20:08 05
drwx------. 2 33 tape 4096 Apr 4 20:08 06
drwx------. 2 33 tape 4096 Apr 4 20:08 07
drwx------. 2 33 tape 4096 Apr 4 20:08 08
drwx------. 2 33 tape 4096 Apr 6 10:23 09
Take care
Ken
