Bugs item #1023760, was opened at 2004-09-07 17:26
Message generated for change (Comment added) made by ralfbecker
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=554338&aid=1023760&group_id=78745
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: preferences
Group: None
Status: Closed
Resolution: None
Priority: 5
Submitted By: mcgursan (depmod13)
Assigned to: Reiner Jung (reinerj)
Summary: egroupware https installation
Initial Comment:
I installed egroupware in …/htdocs/egroupware and
using it via https so it is in a virtual machine root.
Therefore I’ve put nothing in “Enter the location of
eGroupWare’s URL.” in setup. I can’t see the
manual/help icon and icons in infolog (todo,phone,etc)
when I put https://my_address/ instead of nothing
server keeps kicking me out because of https.
Comment By: Ralf Becker (ralfbecker)
Message:
Logged In: YES
user_id=208526
the eGroupWare development team has finished a new release: 1.2
We believe many of the reported bugs are fixed.
As we dont have the time to check all the open bugs, we close
them now and kindly ask you to re-check your bug-report with the
new release.
If you find your reported bug still exists in the new release
(1.2RC7), please reopen the bug-report.
Thanks for your understanding and we hope you enjoy using the new
release.
Comment By: mcgursan (depmod13)
Message:
Logged In: YES
user_id=1117402
Sorry about that I use Mandrake 10, Apache 2.0, PHP 4.3.4,
OpenSSL, mod_security, egroupware is installed in
htdocs/egroupware and I use a secure virtual server to access
egroupware. When I use https, I can neither see the picture of
Manual on the menubar at the top nor I can enter it. When I
click on the manual on menubar it gives me a 404 error. But
when I use http instead of https everything works perfectly. I
checked apache error log there is no entry. As I said I’ve put .
. for installation path of egroupware since users log in from
192.168.2.155 (static IP) when inside the lan via http and
login from ADSL dynamic ip through internet via https.
Comment By: Reiner Jung (reinerj)
Message:
Logged In: YES
user_id=775404
I can’t reproduce this problem. What you setup ?
Message:
Logged In: YES
user_id=1117402
I managed to use “…” instead now it seems working but just
the manual i can see it’s icon on http but can’t see it on https
eGroupWare-tracker mailing list
eGroupWare-tracker@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/egroupware-tracker
