Bugs item #1350091, was opened at 2005-11-07 10:28
Message generated for change (Comment added) made by ralfbecker
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=554338&aid=1350091&group_id=78745
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: calendar
Group: 1.0 release (closed / no more reports please)
Status: Closed
Resolution: None
Priority: 5
Submitted By: chris78 (christophe78)
Assigned to: Ralf Becker (ralfbecker)
Summary: ICal/rfc2445
Initial Comment:
When you choose ICal/rfc2445 for event format in
preferences,if someone invites you at a rendez-vous then :
- No email is sent to you
- If the user who has scheduled the event tries to
delete it, he cannot. A blank page is displayed and the
event is not deleted.
To be able to delete the event, the invited person
whose event format is set to ICal/rfc2445 has to change
it back to another one (extended or something else).
System configuration:
Apache 2.0
PHP 5.0.3
Chris
Comment By: Ralf Becker (ralfbecker)
Message:
Logged In: YES
user_id=208526
the calendar have been completly rewritten.
I believe most if not all of the reported bugs are fixed. I dont
have the time to check all of the many open bugs of the old
calendar code.
Therefor I will close now all bugs from the 1.0 calendar.
If you find your reported bug still exists in the new calendar
code (1.2RC2), please reopen the bug-report.
I hope you enjoy using the new calendar.
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
eGroupWare-tracker mailing list
eGroupWare-tracker@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/egroupware-tracker
