Bugs item #1433518, was opened at 2006-02-17 12:20
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=554338&aid=1433518&group_id=78745
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: felamimail
Group: 1.2 RC5, no more RC1-4 please !!!
Status: Open
Resolution: None
Priority: 5
Submitted By: Aleksander Adamowski (the_olo)
Assigned to: Lars Kneschke (lkneschke)
Summary: FelaMiMail cache SQL error on PostgreSQL
Initial Comment:
I’m using eGroupWare 1.2 RC6 with PostgreSQL 8.0.7 on
Fedora Core 4.
The users are authenticated in LDAP, but accounts and
contacts are stored in the SQL database.
I’ve discovered a problem in FelaMiMail’s cache module
(or possibly its database schema - a field is too short):
Database error: Invalid SQL: INSERT INTO
egw_felamimail_cache
(fmail_date,fmail_subject,fmail_sender_name,fmail_sender_address,fmail_to_name,fmail_to_address,fmail_size,fmail_attachments,fmail_accountid,fmail_hostname,fmail_foldername,fmail_accountname,fmail_uid)
VALUES (1079713146,’[ANNOUNCE] uniqueidentifier
datatype for 7.2.X’,‘Dmitry G. Mastrukov
=?koi8-r?Q?=E4=CD=C9=D4=D2=C9=CA_?=
=?koi8-r?Q?=E7=C5=CE=CE=C1=C4=D8=C5=D7=C9=DE_?=
=?koi8-r?Q?=ED=C1=D3=D4=D2=C0=CB=CF=D7?=’,‘dmitry@taurussoft.org’,‘psql-announce
mailing
list’,‘pgsql-announce@postgresql.org’,2792,‘false’,1422,‘localhost’,‘INBOX.Announce’,‘olomaillists’,123)
pgsql Error: -1 (ERROR: value too long for type
character varying(120))
File:
/var/www/html/egroupware/felamimail/inc/class.socaching.inc.php
Line: 66
Function: egw_db::insert / socaching::addToCache /
bocaching::addToCache / bofelamimail::updateCache /
bofelamimail::getHeaders / uifelamimail::viewMainScreen
/ ExecMethod()
Session halted.
eGroupWare-tracker mailing list
eGroupWare-tracker@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/egroupware-tracker
