[eGroupWare-tracker] [ egroupware-Bugs-1370783 ] Group planer, add persons through popup window
Bugs item #1370783, was opened at 2005-12-01 11:13
Message generated for change (Comment added) made by ralfbecker
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=554338&aid=1370783&group_id=78745
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: calendar
Group: 1.2 RC3, no more RC1+2 please !!!
Status: Closed
Resolution: Works For Me
Priority: 5
Submitted By: Stefan Dannemann (sdann_listen)
Assigned to: Ralf Becker (ralfbecker)
Summary: Group planer, add persons through popup window
Initial Comment:
You need:
  • configure “person select in popup window”
  • a huge group > 20 persons, to get the group listing
    over several pages
  • the group planner
  • a sight, that does not contain your calendar
    – all works fine, if your calender is selected
You cannot add two persons of the same group, if tey
are on different pages of the “person select” popup
window.
  • Changing pages through arrow button is not possible
  • search over persons clears actual selection
Comment By: Ralf Becker (ralfbecker)
Message:
Logged In: YES
user_id=208526
if you first change to a selection of multiple users (shown
as multiple in the selectbox) and then use the arrows in the
popup, the selection got lost, but it it actualy working if
you click on send you get the planner with the persons
selected (if they have appointments in the selected
timespan, otherwise the persons get omitted).
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
eGroupWare-tracker mailing list
eGroupWare-tracker@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/egroupware-tracker
