Hi Nathan and Michele,
below is the _debug_array($data); die(); output for report_purchase_order,
like Nathan suggested. You will observe that there are informations about
"our tel work", “supplier tel work” and about PO lines and totals. The
informations are received by the arrays, …
[our_contact] =>
[their_contact] => Array
What can we do? Help me please!!!
I notice that the total and sub-total for this PO are to be displayed
as 0,00, but there is one line for 1006,76. Something strange there,
but probably not causing this issue. Might be an issue with how the
total and taxes are calculated.
You can see from your output that ‘our_contact’ is in fact empty.
Your debug shows that you have a shipping and billing address, but
’our_contact’ is blank.
I also noticed in your pdf that it changes font for some of the values
(see pay address). That’s weird, as the output should be simple text
with no font information.
Do all your orders lack the ‘Our Contact’? Can non-admins edit purchase orders?
At this point, I recommend manually editing your database (perp_order
table) and putting your contact ID (not account ID) into the
our_contact field of that record. Maybe that will help.
Nathan
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon’s best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Perp-developers mailing list
Perp-developers@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/perp-developers
