I can read email but cant forward or reply. When I do I get I get a
’page not found":
In config applications/possible solutions I get the following message
“Email” is broken because it depends upon:
phpgwapi: 0.9.13, 0.9.14, 0.9.15, 1.0.0
The table definition was correct, and the tables were installed.
However, the application is otherwise installed.
Go back
my phpgwapi is in the normal place egroupware/phpgwapi, and should
work. I also notice several other apps list similar errors
any help will be greatly appreciated
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
’page not found":
Is this a new installation, what version? Did you follow the installation
procedure - did you run http://localhost/egroupware/setup before anything else?
this is a new install of 1.2-105 over an existing install. The
existing install had the same problem. I ran egroupware/setup first
of course for both installs.
The problem seems universal with all apps reporting similar errors
with phpgwapi.
Thanks,
Brian
I run 1.2.105 too (without the problem you’re seeing), but I’ve always
updated since pre version 1.0. Have you tried a complete checkout
from subversion? If you’re on a Linux box do: mv
/usr/share/egroupware /usr/share/egroupware_bak
cd /usr/share
svn checkout http://svn.egroupware.org/egroupware/branches/1.2/aliases/default
svn checkout http://svn.egroupware.org/egroupware/branches/1.2/email
egroupware # if you use AngleMail
cp /usr/share/egroupware_bak/header.inc.php
/usr/share/egroupware - you’ll probably have to
restore the ownership/permissions on /usr/share/egroupware.
Then go thru the setup procedure again - do a Check Installation, and
go and check on the status of the applications. If you see any
problems in these two steps, fix them first before even trying to
continue with loggin on. Also, provide more info on what O.S. and
versions of PHP/database you’re running, and what did you install
from (debs/RPMs/tar/svn).
