I’m having trouble install eGroupWare. I have installed XAMPP and
verified that it is working. I then installed eGroupWare to the
/opt/lampp/htdocs directory. I then pointed my browser to
http://localhost/egroupware and saw the initial setup screen.
I went through eGroupWare’s inital setup screen and everything was ok.
I then went through the create header screen. A header file was
created but the setup screen said that it did not have rights to
create the file so that I was to take the file and rename it
header.inc.php and put it in the correct spot.
So I put it in the eGroupWare root directory at
/opt/lampp/htdocs/egroupware. I then was sent back to the first
screen but I got the following error:
Warning: include (./header.inc.php) function include failed to open
stream: Permission denied in
/opt/lampp/htdocs/egroupware/setup/inc/functions.inc.php on line 26
Would someone mind telling me what I have done wrong.
Thanks
Alex
I am following the setup instructions exactly.
What would be the right permissions etc for this file?
Thanks
Alex
well I tried to fugure out under which account Apache is running. I
took a guess that www-data was right. So I ran:
chown www-data:www-data egw/
chmod 700 egw/
then I restarted the web server.
Now I get an error:
Forbidden
You don’t have permission to access /egroupware/login.php on this
server.
Obviously I picked the wrong user. Can you tell me how to pick the
correct user?
I’m running XAMPP. I thought that would simplify things. It was pretty
hard to start but so far no luck with eGroupWare.
Alex
ps -ef | grep apache
El dl 22 de 05 del 2006 a les 15:10 +0000, en/na acolic va escriure:
chmod 700 egw/
Now I get an error:
Forbidden
server.
correct user?
Alex
àngel bosch
Departament de Sistemes i Comunicacions
Brújula Telecom
T. +34 971 433 909 - F. +34 971 433 910
www.brujulatelecom.com
En el cor del seu negoci
Thanks,
when I ran that command I got:
acolic 12443 9215 0 12:58 pts/0 00:00:000 grep apache.
So I ran:
chwon acolic egroupware/
and
chmod 700 egroupware/
and I still get that forbidden access error.
Did I follow the steps correctly?
Well no luck. I ran the command within each directory. Every file says
that acolic is the owner.
I still get a forbidden access when I try to access the
/setup/index.php page.
Any idea of figuring out what user apache things should have access to
this page?
Alex
If you actually got only that single line it means that no apache web
server is running!
Udo Burghardt
Institut für Informatik - http://www.ifi.informatik.uni-goettingen.de
0551 / 39-14405
try to modify/rename/delete .htaccess from the egroupware directory.
False settings can cause your problem.
Best regards,
Johannes Weberhofer
server is running!
Not necessarily, apache runs as httpd.
If “httpd” is not in a subdirectory called “apache” or it is run without
its complete path, grep wouldn’t find it.
try ps -ef |grep httpd instead.
Robert Steinmetz, AIA
Principal
Steinmetz & Associates
Thanks I got the second step working. Looks like changing the
permissions worked.
Alex
All the advantages of Linux Managed Hosting–Without the Cost and Risk!
Fully trained technicians. The highest number of Red Hat certifications in
the hosting industry. Fanatical Support. Click to learn more
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=107521&bid=248729&dat=121642
