Dear all,
I’ve installed egw 1.2 rc7.
I was trying to follow the etemplates tutorial, but it seems that etemplates
is not working properly in rc7.
I get stuck in step 3, after creating (saving) the etemplate, I do not see
the pink square mentioned in the tutorial
(http://egroupware.org/egroupware/etemplate/doc/etemplate.html).
I’ve tried wit IE and FireFox, no luck.
BTW, I’d like to know if there are other docs explaining how to integrate
apps into egw.
Thanks in advance,
R.
nubeiro schrieb:
Dear all,
I’m pretty sure it’s working properly, otherwise many apps would not work.
The pink square is a mouse over, means it only appears if you move the
mouse over that location. If you are in the right spot (see the pink
mouseover) you can doubleclick on it to open the edit-widget popup.
apps into egw.
Have a look at the Developer Docs in the wiki:
http://egroupware.org/wiki/DeveloperDocs
