Feature Requests #1069: addressbook, numbers of entries to be exported, "0" to deny
Ticket modified by Tracking System at 2010/12/18 12:03
Tracking System: Feature Requests
Category: Addressbook
Version: Trunk
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Frank Drews
Assigned to: Ralf Becker
Summary: #1069 - addressbook, numbers of entries to be exported, “0” to deny
addressbook configuration to limit the number of entries to be exported :
At the moment if you set the number to “0” the window will close, giving you the impression, that it worked. Unfortunately, “0” is not accepted, the field is empty an the export is unlimited.
It would be just great if setting the limit to 0 would mean, that you couldn’t export no data at all. That would be quite easy to understand for the admins, and something I would appreciate. If would be even better if setting it to 0 would mean, that the export options would disappear from the dropdown menue.
Comment by Tracking System at 2010/12/18 12:03:
Comment by Ralf Becker at 2010/12/04 11:47:
Dear EGroupware user,
thanks for reporting feature requests to egroupware.org.
With the new release of EGroupware 1.8.001 we implemented many new features. So we kindly ask you to recheck your feature request against the new version. If it is still valid, please reopen it with the current version 1.8.001.
If you do not respond within the next 14 days, we assume the request is no longer necessary and it will be closed automatically.
Thanks for your understanding
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=1069&no_popup=1
