Feature Requests #1553: Possibility to create Tracker from infolog directly
Ticket modified by Ralf Becker at 2010/12/04 11:38
Tracking System: Feature Requests
Category: Tracker
Version: Version 1.4 (unsupported)
Status: Pending
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Maciej Wasyluk
Assigned to: Ralf Becker
Summary: #1553 - Possibility to create Tracker from infolog directly
I’d like to request a possibility to create tracker from infolog directly, same way as you’d create infolog from projectmanager.
Once you choose to create an infolog from project, it’s automatically added as an element of project. Making it possible to do with infolog and tracker gives us possibility to quickly connect infolog with belonging tracker.
Especially when you use a structure of: Project (as an outline) -> Infolog (as todo’s of project/ do-able actions) -> and Tracker (as discussions and communication regarding an Infolog). Than such an addition would be a way to connect things much quicker than current way when you have to firstly create the Tracker separately and than bend it into an Infolog.
Comment by Ralf Becker at 2010/12/04 11:38:
Dear EGroupware user,
thanks for reporting feature requests to egroupware.org.
With the new release of EGroupware 1.8.001 we implemented many new features. So we kindly ask you to recheck your feature request against the new version. If it is still valid, please reopen it with the current version 1.8.001.
If you do not respond within the next 14 days, we assume the request is no longer necessary and it will be closed automatically.
Thanks for your understanding
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=1553&no_popup=1
