Ticket modified by Tracking System at 2010/12/18 12:03
Tracking System: Feature Requests
Category: API
Version: Version 1.6 (unsupported)
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: kursat taskin
Assigned to: Ralf Becker
Summary: #1960 - Reporting Module
We need a reporting module to report anything in db. for example it will be better to report whole timesheet entries and project duration like planned man days vs actual man days
Comment by Tracking System at 2010/12/18 12:03:
Comment by Ralf Becker at 2010/12/04 11:40:
Dear EGroupware user,
thanks for reporting feature requests to egroupware.org.
With the new release of EGroupware 1.8.001 we implemented many new features. So we kindly ask you to recheck your feature request against the new version. If it is still valid, please reopen it with the current version 1.8.001.
If you do not respond within the next 14 days, we assume the request is no longer necessary and it will be closed automatically.
Thanks for your understanding
Comment by István Pongrácz at 2009/05/02 10:53:
This kind of request is a key point to use egw in an enterprise.
I run into this issue several times.
As the original reporter wrote, showing the planned/actual man days in a built-in interface would be really useful with filters for date range, projects, groups, individual users.
An other tool could be used for data mining, such as jaspertool. Probably using jasper as a general report tool and creating a huge collection of reports developed by developers/users could give a really good tool to cover a lot of HR related tasks.
Just some thoughts:
Reporting working hours for employee: work shift (normal, nightly, weekend, overtime etc.), holiday, sickness time, project related time etc.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=1960&no_popup=1
