Feature Requests #2615: Field for easy select how much items should be shown
Ticket modified by Tracking System at 2010/12/18 20:08
Tracking System: Feature Requests
Category: FelamiMail
Version: Trunk
Status: Closed
Resolution: Accepted
Completed: 10%
Priority: 5 - medium
Created By: camel camel
Assigned to: Klaus Leithoff
Summary: #2615 - Field for easy select how much items should be shown
field for easy select how much items should be shown
dropdownbox with -1/5/10/20/50/100/500/999
i know, that this can be configured in settings, but it will be very useful if it could be easily set (like as it is in infolog or calendar or addressbook)
Comment by Tracking System at 2010/12/18 20:08:
Comment by Ralf Becker at 2010/12/04 19:47:
Dear EGroupware user,
thanks for reporting feature requests to egroupware.org.
With the new release of EGroupware 1.8.001 we implemented many new features. So we kindly ask you to recheck your feature request against the new version. If it is still valid, please reopen it with the current version 1.8.001.
If you do not respond within the next 14 days, we assume the request is no longer necessary and it will be closed automatically.
Thanks for your understanding
Comment by camel camel at 2010/05/25 23:23:
well, my meaning…
there is the “DELETE” (graph X) on right side of an items, which i would use for …
because if someone wants to delete, he can select it there and in the list below (button right), there he can select what he want to do: ex: export/delete or whatever …
so, then multiple delete is possible.
of course, i know it is a lot of work …
thanks for taking care of it :slight_smile:
Comment by camel camel at 2010/05/25 13:09:
well, my meaning…
Comment by Klaus Leithoff at 2010/05/25 12:32:
problem here is where to add that, as it is pretty crowded in the lists navigation-bar already.
As such I accept the feature request, as I regard that as a worthwhile addition regarding usability but it may take a while.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2615&no_popup=1
