Ticket modified by Birgit Becker at 2011/01/05 17:37
Tracking System: Feature Requests
Category: Tracker
Version: Version 1.8.001
Status: Closed
Resolution: Rejected
Completed: 0%
Priority: 5 - medium
Created By: Peter Tuhársky
Assigned to: Ralf Becker
Summary: #982 - Tracker -reverse priority order
Please, reverse order of priority so that HIGH priority would reside on TOP and LOW priority at BOTTOM of the selectbox.
Comment by Peter Tuhársky at 2011/01/05 12:10:
Understood.
Comment by Birgit Becker at 2011/01/05 11:56:
Hi Peter,
its simply at the moment in etemplate not possible to have it the other way round as default, all filterheaders are "A–>Z, 1–>9".
Birgit
Comment by Peter Tuhársky at 2010/12/22 10:22:
Not exactly. It is pre-defined in eGW at first place (1 - lowest, 9 - highest). Only at the end the user can re-define it. I think the default should work smoothly without the need to redefine it upwards down
Comment by Birgit Becker at 2010/12/20 17:03:
As you can define, whats high and low priority means, this will not be changed
Birgit
Comment by Peter Tuhársky at 2010/12/20 14:30:
Still incorrect in 1.8
Comment by Tracking System at 2010/12/18 12:03:
Comment by Ralf Becker at 2010/12/04 11:38:
Dear EGroupware user,
thanks for reporting feature requests to egroupware.org.
With the new release of EGroupware 1.8.001 we implemented many new features. So we kindly ask you to recheck your feature request against the new version. If it is still valid, please reopen it with the current version 1.8.001.
If you do not respond within the next 14 days, we assume the request is no longer necessary and it will be closed automatically.
Thanks for your understanding
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=982&no_popup=1
