How to add FUDforum
Hello All,
is it possible to install fudforum in the latest version of Egroupware i am
using eGroupWare-1.2RC5-1.tar.gz but i cannot found fudforum or i cant
install it…
If I compare to a previous version eGroupWare-1.0.0.009-3.noarch.rpm i can
and easy to install fudforum…
is there any way to install fudforum
Thank you…
RHSumook
Philippines
http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
