Please replace “tts” with the name of the application you want to check out,
eg. use “xmlrpc” if you want the xmlrpc app:svn checkout
http://svn.egroupware.org/egroupware/branches/1.2/xmlrpcRalf "Lannehoa.Pro"
lannehoa.pro@tourellerie.fr schrieb:
Hi
This
http://www.egroupware.org/index.php?page_name=wiki&wikipage=subversion
Describe
To get all default applications of the stable 1.2 branch, just do the
following in your docroot:
Further (contrib) applications can be checked out, eg. for the tts app
with:
cd /var/www/html/egroupware #or where ever you installed eGW
svn checkout http:/ /svn.egroupware.org/egroupware/branches/1.2/tts
But
Do not include xmlrpc application
YL
Ralf Becker a écrit :
Hi,the subversion page in our wiki describs how to install other
(contrib)
apps via subversion.Ralf "Lannehoa.Pro"
schrieb:
Thank-you
Little question : I have installed Egw with svn, and it’s the 1.2.106
version.
I don’t found xmlrpc app in the contrib files ?
Can I install the xmlrpc from 1.2.105 version ?
YL
a) install it:
- debian apt-get install subversion
- redhat, fc, suse: yum install subversion
- suse: yast -i subversion
b) use the snapshot: http://www.egroupware.org/downloads
Lannehoa.Pro schrieb:
Hello
What can we do when svn command not work ?
bash: svn: command not found
YL
Just copy the header.inc.php to your new checkout - tought this is
obvious
bobe schrieb:
Ralf Becker wrote:
This is no good idea, you should always do something like:
cd /var/www
mv egroupware egroupware.old
svn co http://svn.egroupware.org/egroupware/trunk/aliases/default .
But then I have to setup/configure all over again?
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your
job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Geronimo
easier
