I have been struggling with the installation of egroupware. It will not complete the setup, various elements give the error message:
| An error happened
| SQLSTATE[08006] [7] could not translate host name “port=5432” to address: Name or service not known
I have tried redoing the header admin setup and leaving the port number blank, since it is the default for postgresql, but this makes no difference.
I assume this is not a bug – but can anyone suggest which config file I should edit to avoid this problem?
TIA
