Hi all,
since upgrade from 1.6 to 1.8 I cannot get a full working EGW 1.8.
I have had 1.6 on Ubuntu 8.04, everything was fine.
With the upgrade to 1.8. I upgraded to Ubuntu 10.10 too.
After some days, I noticed the “bug” with the Search in Timesheets (and Infologs too):
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2791
http://www.egroupware.org/forum#nabble-td2332270
Afterward I downgraded the server to Ubuntu 8.04 (PHP 5.2.4). The search is fine now, but EGW doesn’t send e-mails (notifications) anymore.
It seems there are some php-issues (5.2.4 vs. 5.3.2/5.3.3) with phpmailer too.
After many unsuccessful attempts I have now the following combinations:
EGW 1.6 on Ubuntu 8.04 e-mails and search/linking are fine (there is no the same search in timesheets on 1.6 but the same issue exists for linking in Infologs)
EGW 1.8 on Ubuntu 8.04 - search OK, e-mail notifications don’t work
EGW 1.8 on Ubuntu 10.04 - search doesn’t work, e-mail notifications OK
EGW 1.8 on Debian 5 - search OK, e-mail notifications don’t work
EGW 1.8. on Ubuntu 10.10 - search doesn’t work properly (php 5.3.3)
The delivery server are Postfix and Dovecot on all installations.
I tried OpenSuse 11.3 too, the search doesn’t work either
It is possible that the e-mail bug doesn’t occur by all installations, because I have only local delivery (server address “localhost”), the real delivery over internet may work, this I don’t know.
So my question is:
Is there anybody whose EGW 1.8. works (= the aformentioned bug 2791 doesn’t occur and the e-mail notifications are getting sent)?
Could you please tell me which server you run (version of php, mailserver)?
I am going to try Fedora and Centos, but I’m running out of time, and it is very frustrating to install a new server with the same failure
Maybe could the developers in Stylite tell on which software they run their developement?
Many thanks for advice
Martin
