I’m trying to install egroupware with authentication from ldap.
but egroupware is not able to create accounts in ldap eventhough
rootdn password is correct.
so i wanted to manuall add entries in ldap through ldapadd command.
So if any one has sample ldif file can u post it .
thanks-hari
That’s no good idea with eGroupWare 1.2.
Better check the ldap server log and look for the problem.
With eGroupWare > 1.2 (aka the devel version) you can safely add entries to
ldap directly.
