Multiple eGroupWare machines
Hello,
Is it possible to sync multiple eGroupWare servers? In particular the
calendar? For the Wiki and some other modules, it should be possible
to just link to the main server, and just prevent updates on the
others.
Can you just cron an xml-rpc statement? Per user? Something like:
for USER in select * from users
do
wget http://other.server/xmlrpc.php?${USER}
done
and if so, what would process the xml?
Regards,
Berend
Confidentiality notice: http://ucs.co.za/conf.html
