Hi.
If your shared server has support for PEAR (rare!), and you have installed it into /user/homepage/PEAR then:
Your pear channel php_dir must be set to the PHYSICAL PATH - not URL - of /user/homepage and not /user/homepage/PEAR.
Your php.ini include path must then be set to the very same PHYSICAL PATH as above.
Please note that php.ini’s CAN be set for each directory, once again depending on your server hosting plan and access rights. However, php.ini’s are NOT INHERITANT, ie
the full declarations have to be repeated in case you have multiple php.ini’s.
EGW will find manually installed packages in egw-pear as it adds the egw-pear directory to the include path during runtime.
This does not work autmagically for your shared pear directory. Hence you have to set it manually in php.ini.
And the pear installer adds automatically a /PEAR subdirectory to the install path noted in the channel definition. Hence you should not point it to /xyz/PEAR but /xyz.
Hope that helps a bit.
Cheers,
Ingo
Hi Ingo,
Thank you for the detailed reply! I’m on 1and1 shared hosting. Here’s what
I don’t understand I install the Pear package and with including Auth_SASL
and XML_Feed_Parser. I got to check install page in egroupware and it says
I don’t have Auth_SASL" and XML_Feed_Parser installed. If I copy the
package into /egw-pear then the check install page says I have both
installed.
So if I install Pear in a /user/homepage/PEAR directory how do I connect
egroupware to recognize the needed Pear packages if egroupware is looking
for them in /egw-pear?
View this message in context: http://egroupware.219119.n3.nabble.com/Pear-Question-tp3276707p3420350.html
Sent from the egroupware-users mailing list archive at Nabble.com.
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2d-oct
