Problem with email links
Hello,
We have a problem with email links. Using the first link after logging opens the correct infolog but clicking on the following ones always opens the first. You have to disconnect and reconnect for it to work again but just once.
Regards
Régis
egroupware-problem-20201208.pdf (269.9 KB)
EGroupware 20.1.20201202
database : Mariadb
Web Server : docker egroupware-nginx
Hi Régis.
Please take a look at the sorce of the e-mail.
Are the links different (i.e. correct), or does the email already contain the same information?
Hi Stefan
links are different and look ok
email 1 :
https://xxx/egroupware/index.php?menuaction=infolog.infolog_ui.edit&info_id=8676&no_popup=1
email 2
https://xxx/egroupware/index.php?menuaction=infolog.infolog_ui.edit&info_id=8677&no_popup=1
Regards
Régis
Hi Régis.
You opened the links from an external e-mail-client (Thunderbird), right?
What happens when you open the links from the EGw-Mailer?
OK, i can reproduce your problem…
Ticket is created and given to the developer.
Hello,
The problem remains after installing the latest version (20.1.20210125).
Do you know if the developers have planned this fix?
Regards
Régis
