I get the following error in /tmp/egroupware_syncml.log:
Sep 02 01:18:06 EGWSYNC [error]
[] SyncML: Error in replacing/add client entry:The
method “scard/import” is not defined in the Horde Registry.
[on line 217 of
"/usr/share/egroupware/phpgwapi/inc/horde/Horde/SyncML/Sync/SlowSync.php"]
I take it the default values in the Sync4j client version 2.0.34
(Syncronization Settings -> Remote Settings) of Contact Name =
scard, and Calendar Name = scal, is incorrect? I can’t seem to find
documentation on what to set this to. I’m using eGW 1.2.104, any
help would be greatly appreciated.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
I’ve now updated (using the latest v.3.0.7 of Funambol), and changed
my Remote Settings to ./sifcontacts and ./sifcalendar. Funambol (and
my /tmp/egroupware_syncml.log) reports that the syncronization
completed successfully, but Outlook is not updated with the latest in
eGW calendar.
I’m getting this from my syslog (/var/log/messages) at the time that I
attempt to sync:
httpd: PHP Warning: array_shift()
[function.array-shift]:
The argument should be an array in
/usr/share/egroupware/phpgwapi/inc/horde/Horde/SyncML/Sync/TwoWaySync.php
on line 66This seems like a problem, anyone with
an idea?
