I got this error message from jpgraph, when I try to make a ganttchart.
Latest svn update (this morning).
Probably it is solved, I will check it this evening (mailinglist & source).
Any comment are welcome.
IStván
IStván
I forgot to write, I overwrited the jpgraph directory with jpgraph-1.20.2.
I checked the conversation with the same issue (except my jpgraph version).
I have to leave now, in the evening I will try to solve it based on the emails
IStván
opinions on IT & business topics through brief surveys – and earn cash
After a short playing and reading carefully the original post by John Thomas and
Ralf, and digging a little the new version of jpgraph, there is a nice place,
where I put the famous
DEFINE(“TTF_DIR”,PHPGW_SERVER_ROOT."/projectmanager/inc/ttf-bitstream-vera-1.10/");
line.
into jpg-config.inc located in jpgraph directory.
Seems everything fine, except my chars. Probably I put an utf8 character set to
get my characters working (éáúőűóüöí).
István
IStván
Hi Istvan,
if you leave the existing (old) jpgraph directory under projectmanager/inc
alone and install the new jpgraph parallel to egroupware (eg. eGW in
/var/www/html/egroupware you use /var/www/html/jpgraph) it will be
autodetected AND you dont need to edit a single file.
Thomas and
place,
line.into jpg-config.inc located in jpgraph directory.
set to
get my characters working (éáú??óüöí).István
jpgraph-1.20.2.I checked the conversation with the same issue (except my jpgraph
version).I have to leave now, in the evening I will try to solve it based on the
emailsHi,
source).Any comment are welcome.
IStván
your
Outdoor Unlimited Training GmbH
Leibnizstr. 17
67663 Kaiserslautern
Thank you!
This is much better
István
Ralf Becker wrote:
Hi Istvan,
autodetected AND you dont need to edit a single file.Ralf
By the way, to get utf-8 working with my installation (which is needed to get my
characters in the ganttchart) I need to do some tricks
I need to modify a little the source
István
Thank you!
This is much betterIstván
Ralf Becker wrote:
Hi Istvan,
Hi Istvan,
Thomas and
place,
set to
emailsHi,
IStván
your
Leibnizstr. 17
