Author: igel457
New Revision: 31306
URL: http://www.egroupware.org/viewvc/egroupware?rev=31306&view=rev
Fixed felamimail mainscreen not properly being resized to the document height
trunk/felamimail/templates/default/mainscreen.tpl
trunk/felamimail/templates/jerryr/mainscreen.tpl
Modified: trunk/felamimail/templates/default/mainscreen.tpl
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/templates/default/mainscreen.tpl?rev=31306&r1=31305&r2=31306&view=diff
— trunk/felamimail/templates/default/mainscreen.tpl (original)
+++ trunk/felamimail/templates/default/mainscreen.tpl Tue Jul 6 16:42:08 2010
@@ -165,11 +165,11 @@
if the iframe stays maximized. */
if (window.parent && typeof window.parent.framework != ‘undefined’)
var height = $(window).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 70;
var height = $(document).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 70; } else {
var height = $(window).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 90;
var height = $(document).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 90; } /* Tableheight specifies the rendered size of the table,
Modified: trunk/felamimail/templates/jerryr/mainscreen.tpl
URL: http://www.egroupware.org/viewvc/egroupware/trunk/felamimail/templates/jerryr/mainscreen.tpl?rev=31306&r1=31305&r2=31306&view=diff
— trunk/felamimail/templates/jerryr/mainscreen.tpl (original)
+++ trunk/felamimail/templates/jerryr/mainscreen.tpl Tue Jul 6 16:42:08 2010
@@ -170,11 +170,11 @@
if the iframe stays maximized. /
if (window.parent && typeof window.parent.framework != ‘undefined’) / jdots template, does not apply here, as it is using default templates */
var height = $(window).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 85;
var height = $(document).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 85; } else {
var height = $(window).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 112;
var height = $(document).height() - felamimail_iframe_height - $(divMessageTableList).offset().top - 112; } /* Tableheight specifies the rendered size of the table,
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first – http://p.sf.net/sfu/sprint-com-first
eGroupWare-cvs mailing list
