Author: ralfbecker
New Revision: 32276
URL: http://www.egroupware.org/viewvc/egroupware?rev=32276&view=rev
added info about firefox with NTLM and update EGroupware configuration
branches/1.8/phpgwapi/ntlm/README (contents, props changed)
branches/1.8/phpgwapi/ntlm/egroupware.conf (contents, props changed)
Modified: branches/1.8/phpgwapi/ntlm/README
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.8/phpgwapi/ntlm/README?rev=32276&r1=32275&r2=32276&view=diff
— branches/1.8/phpgwapi/ntlm/README (original)
+++ branches/1.8/phpgwapi/ntlm/README Fri Sep 24 08:11:38 2010
@@ -1,5 +1,5 @@
-Steps to set up NTLM Single Sign On for eGroupWare 1.6
+Steps to set up NTLM Single Sign On for eGroupWare 1.6+
(Version: $Id$)
NTLM SSO removes Windows users on a PC, which is a member of a Windows domain
@@ -7,9 +7,10 @@
They simply point IE to the eGW URL (eg. http://domain.com/egroupware/) and
start working. They can of cause explicitly log out and log in as an other user.
-As far as I tested, Firefox 3 only allows to enter user (including domain(!), eg. DOMAIN\user)
-and password in a popup, which then get’s checked from apache via winbind.
-It does NOT automatically log you in, if you’re logged into the domain on your PC!
+Firefox (at least 3.6) requires to manually enable NTLM Auth via about:config:
+search for ntlm and set “network.automatic-ntlm-auth.trusted-uris” to the domain
+your EGroupware install is using. Otherwise you will only get a popup to enter
+username (with prepended windows domain eg. DOMAIN\username) and password.
Here’s in short what you need:
Propchange: branches/1.8/phpgwapi/ntlm/README
svn:keywords = Id
Modified: branches/1.8/phpgwapi/ntlm/egroupware.conf
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.8/phpgwapi/ntlm/egroupware.conf?rev=32276&r1=32275&r2=32276&view=diff
— branches/1.8/phpgwapi/ntlm/egroupware.conf (original)
+++ branches/1.8/phpgwapi/ntlm/egroupware.conf Fri Sep 24 08:11:38 2010
@@ -1,5 +1,8 @@
-# Apache and PHP configuration for eGroupWare using NTLM authentication
+# Apache and PHP configuration for EGroupware using NTLM authentication
+# This version of EGroupware configuration might not be as up to date as
+# the one in /usr/share/doc/rpm-build/apache.conf!
Version: $Id$
@@ -33,14 +36,20 @@
php_flag magic_quotes_gpc off
php_flag magic_quotes_runtime off
php_flag register_globals off
- php_flag short_open_tag on
php_flag track_vars on
- php_value error_reporting E_ALL
- php_flag display_errors off
E_ALL & ~E_NOTICE & ~E_STRICT = 8191 - 8 - 2048 = 6135
- php_value error_reporting 6135
php_value max_execution_time 90
- php_value mbstring.func_overload 7
- php_value memory_limit 48M
- php_admin_value mbstring.func_overload 7
- php_value memory_limit 64M
php_value session.gc_maxlifetime 14400
- php_value open_basedir /usr/share/egroupware:/var/lib/egroupware:/tmp:/var/lib/php5
- php_value upload_max_filesize 16M
- php_value include_path .:/usr/share/pear
- php_admin_value open_basedir /usr/share/egroupware:/var/lib/egroupware:/tmp:/usr/share/pear:/usr/bin/zip:/usr/share/jpgraph:/usr/bin/tnef:/usr/bin/aspell
- php_value upload_max_filesize 64M
- php_admin_value upload_tmp_dir /tmp
- php_value post_max_size 65M
<Files ~ “.inc.php$”>
Order allow,deny
Deny from all
@@ -48,11 +57,15 @@
<Directory /usr/share/egroupware/phpsysinfo/>
+<Directory /usr/share/egroupware/gallery/>
- php_admin_value open_basedir /usr/share/egroupware:/var/lib/egroupware:/tmp:/usr/share/pear:/usr/bin:/bin
<Location /egroupware/rpc.php>
- php_value mbstring.func_overload 0
- php_admin_value mbstring.func_overload 0
Order allow,deny
Allow from all
Propchange: branches/1.8/phpgwapi/ntlm/egroupware.conf
svn:keywords = Id
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
eGroupWare-cvs mailing list
