R32394 - /trunk/admin/inc/
Author: nathangray
New Revision: 32394
URL: http://www.egroupware.org/viewvc/egroupware?rev=32394&view=rev
Basic support for importing groups from CSV
Added:
trunk/admin/inc/class.admin_import_groups_csv.inc.php
trunk/admin/inc/class.admin_wizard_import_groups_csv.inc.php
trunk/admin/inc/class.admin_wizard_import_users_csv.inc.php
Added: trunk/admin/inc/class.admin_import_groups_csv.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/admin/inc/class.admin_import_groups_csv.inc.php?rev=32394&view=auto
— trunk/admin/inc/class.admin_import_groups_csv.inc.php (added)
+++ trunk/admin/inc/class.admin_import_groups_csv.inc.php Wed Sep 29 19:31:36 2010
@@ -1,0 +1,261 @@
+<?php
    • class import_csv for admin (groups)
    +class admin_import_groups_csv implements importexport_iface_import_plugin {
  • private static $plugin_options = array(
  •   'fieldsep', 		// char
  •   'charset', 		// string
  •   'num_header_lines', // int number of header lines
  •   'field_conversion', // array( $csv_col_num => conversion)
  •   'field_mapping',	// array( $csv_col_num => adb_filed)
  •   'conditions',		/* => array containing condition arrays:
  •   		'type' => exists, // exists
  •   		'string' => '#kundennummer',
  •   		'true' => array(
  •   			'action' => update,
  •   			'last' => true,
  •   		'false' => array(
  •   			'action' => insert,
  •   			'last' => true,
    • actions which could be done to data entries
  • protected static $actions = array( ‘none’, ‘update’, ‘create’, ‘delete’);
    • conditions for actions
    • @var array
  • protected static $conditions = array( ‘exists’ );
    • @var definition
  • private $definition;
    • @var bool
  • private $dry_run = false;
    • List of import errors
  • protected $errors = array();
  •     * List of actions, and how many times that action was taken
  •    protected $results = array();
    • imports entries according to given definition object.
    • @param resource $_stream
    • @param string $_charset
    • @param definition $_definition
  • public function import( $_stream, importexport_definition $_definition ) {
  •   $import_csv = new importexport_import_csv( $_stream, array(
  •   	'fieldsep' => $_definition->plugin_options['fieldsep'],
  •   	'charset' => $_definition->plugin_options['charset'],
  •   $this->definition = $_definition;
  •   // dry run?
  •   $this->dry_run = isset( $_definition->plugin_options['dry_run'] ) ? $_definition->plugin_options['dry_run'] :  false;
  •   // set FieldMapping.
  •   $import_csv->mapping = $_definition->plugin_options['field_mapping'];
  •   // set FieldConversion
  •   $import_csv->conversion = $_definition->plugin_options['field_conversion'];
  •   //check if file has a header lines
  •   if ( isset( $_definition->plugin_options['num_header_lines'] ) && $_definition->plugin_options['num_header_lines'] > 0) {
  •   	$import_csv->skip_records($_definition->plugin_options['num_header_lines']);
  •   } elseif(isset($_definition->plugin_options['has_header_line']) && $_definition->plugin_options['has_header_line']) {
  •   	// First method is preferred
  •   	$import_csv->skip_records(1);
  •   // Start counting successes
  •   $count = 0;
  •   $this->results = array();
  •   // Failures
  •   $this->errors = array();
  •   while ( $record = $import_csv->get_record() ) {
  •   	$success = false;
  •   	// don't import empty records
  •   	if( count( array_unique( $record ) ) < 2 ) continue;
  •   	if ( $_definition->plugin_options['conditions'] ) {
  •   		foreach ( $_definition->plugin_options['conditions'] as $condition ) {
  •   			switch ( $condition['type'] ) {
  •   				// exists
  •   				case 'exists' :
  •   					$accounts = $GLOBALS['egw']->accounts->search(array(
  •   						'type' => 'groups',
  •   						'query' => $record[$condition['string']],
  •   						'query_type' => $condition['string']
  •   					if ( is_array( $accounts ) && count( $accounts ) >= 1 ) {
  •   						// apply action to all contacts matching this exists condition
  •   						$action = $condition['true'];
  •   						foreach ( (array)$accounts as $account ) {
  •   							$record['account_id'] = $account['account_id'];
  •   							$success = $this->action(  $action['action'], $record, $import_csv->get_current_position() );
  •   					} else {
  •   						$action = $condition['false'];
  •   						$success = ($this->action(  $action['action'], $record, $import_csv->get_current_position() ));
  •   					break;
  •   				// not supported action
  •   				default :
  •   					die('condition / action not supported!!!');
  •   					break;
  •   			if ($action['last']) break;
  •   	} else {
  •   		// unconditional insert
  •   		$success = $this->action( 'insert', $record, $import_csv->get_current_position() );
  •   	if($success) $count++;
  •   return $count;
    • perform the required action
    • @param int $_action one of $this->actions
    • @param array $_data contact data for the action
    • @return bool success or not
  • private function action ( $_action, $_data, $record_num = 0 ) {
  •   switch ($_action) {
  •   	case 'none' :
  •   		return true;
  •   	case 'update' :
  •   	case 'create' :
  •   		$command = new admin_cmd_edit_group($data['account_lid'], $_data);
  •   		if($this->dry_run) {
  •   			$this->results[$_action]++;
  •   			return true;
  •   		try {
  •   			$command->run();
  •   		} catch (Exception $e) {
  •   			$this->errors[$record_num] = $e->getMessage();
  •   			return false;
  •   		return true;
  •   	default:
  •   		throw new egw_exception('Unsupported action');
    • returns translated name of plugin
    • @return string name
  • public static function get_name() {
  •   return lang('Group CSV import');
    • returns translated (user) description of plugin
    • @return string descriprion
  • public static function get_description() {
  •   return lang("Creates / updates user groups from CSV file");
    • retruns file suffix(s) plugin can handle (e.g. csv)
    • @return string suffix (comma seperated)
  • public static function get_filesuffix() {
  •   return 'csv';
    • return etemplate components for options.
    • @abstract We can’t deal with etemplate objects here, as an uietemplate
    • objects itself are scipt orientated and not “dialog objects”
    • @return array (
    •  name 		=> string,
    •  content		=> array,
    •  sel_options => array,
    •  preserv		=> array,
  • public function get_options_etpl() {
  •   // lets do it!
    • returns etemplate name for slectors of this plugin
    • @return string etemplate name
  • public function get_selectors_etpl() {
  •   // lets do it!
  •    * Returns errors that were encountered during importing
  •    * Maximum of one error message per record, but you can append if you need to
  •    * @return Array (
  •    *       record_# => error message
  •    public function get_errors() {
  •   return $this->errors;
  •    * Returns a list of actions taken, and the number of records for that action.
  •    * Actions are things like 'insert', 'update', 'delete', and may be different for each plugin.
  •    * @return Array (
  •    *       action => record count
  •    public function get_results() {
  •            return $this->results;
+} // end of iface_export_plugin
Added: trunk/admin/inc/class.admin_wizard_import_groups_csv.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/admin/inc/class.admin_wizard_import_groups_csv.inc.php?rev=32394&view=auto
— trunk/admin/inc/class.admin_wizard_import_groups_csv.inc.php (added)
+++ trunk/admin/inc/class.admin_wizard_import_groups_csv.inc.php Wed Sep 29 19:31:36 2010
@@ -1,0 +1,53 @@
+<?php
+class admin_wizard_import_groups_csv extends importexport_wizard_basic_import_csv
    • constructor
  • function __construct()
  •   parent::__construct();
  •   $this->steps += array(
  •   	'wizard_step50' => lang('Manage mapping'),
  •   // Field mapping
  •   $this->mapping_fields = array(
  •   	'account_lid'		=> lang('Account ID'),
  •   	'account_name'		=> lang('Group Name'),
  •   	'account_members'	=> lang('Members'),
  •   // Actions
  •   $this->actions = array(
  •   	'none'		=>	lang('none'),
  •   	'update'	=>	lang('update'),
  •   	'create'	=>	lang('create'),
  •   	'delete'	=>	lang('delete'),
  •   // Conditions
  •   $this->conditions = array(
  •   	'exists'	=>	lang('exists'),
  • function wizard_step50(&$content, &$sel_options, &$readonlys, &$preserv)
  •   $result = parent::wizard_step50($content, $sel_options, $readonlys, $preserv);
  •   return $result;
Modified: trunk/admin/inc/class.admin_wizard_import_users_csv.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/admin/inc/class.admin_wizard_import_users_csv.inc.php?rev=32394&r1=32393&r2=32394&view=diff
— trunk/admin/inc/class.admin_wizard_import_users_csv.inc.php (original)
+++ trunk/admin/inc/class.admin_wizard_import_users_csv.inc.php Wed Sep 29 19:31:36 2010
@@ -1,6 +1,6 @@
<?php /** - * eGroupWare - Wizard for Adressbook CSV import + * eGroupWare - Wizard for user CSV import * * @license http://opensource.org/licenses/gpl-license.php GPL - GNU General Public License * @package addressbook ------------------------------------------------------------------------------ Start uncovering the many advantages of virtual appliances and start using them to simplify application deployment and accelerate your shift to cloud computing. http://p.sf.net/sfu/novell-sfdev2dev _______________________________________________ eGroupWare-cvs mailing list eGroupWare-cvs@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/egroupware-cvs
