Author: nathangray
New Revision: 32509
URL: http://www.egroupware.org/viewvc/egroupware?rev=32509&view=rev
Add exporting iCal and CSV via importexport
Added:
trunk/calendar/inc/class.calendar_egw_record.inc.php
- copied, changed from r32506, trunk/addressbook/inc/class.addressbook_egw_record.inc.php
trunk/calendar/inc/class.calendar_export_csv.inc.php
- copied, changed from r32506, trunk/addressbook/inc/class.addressbook_export_contacts_csv.inc.php
trunk/calendar/inc/class.calendar_wizard_export_csv.inc.php
- copied, changed from r32506, trunk/addressbook/inc/class.addressbook_wizard_export_contacts_csv.inc.php
trunk/calendar/setup/etemplates.inc.php
Copied: trunk/calendar/inc/class.calendar_egw_record.inc.php (from r32506, trunk/addressbook/inc/class.addressbook_egw_record.inc.php)
URL: http://www.egroupware.org/viewvc/egroupware/trunk/calendar/inc/class.calendar_egw_record.inc.php?p2=trunk/calendar/inc/class.calendar_egw_record.inc.php&p1=trunk/addressbook/inc/class.addressbook_egw_record.inc.php&r1=32506&r2=32509&rev=32509&view=diff
— trunk/addressbook/inc/class.addressbook_egw_record.inc.php (original)
+++ trunk/calendar/inc/class.calendar_egw_record.inc.php Wed Oct 13 00:45:02 2010
@@ -1,28 +1,26 @@
Copied: trunk/calendar/inc/class.calendar_export_csv.inc.php (from r32506, trunk/addressbook/inc/class.addressbook_export_contacts_csv.inc.php)
URL: http://www.egroupware.org/viewvc/egroupware/trunk/calendar/inc/class.calendar_export_csv.inc.php?p2=trunk/calendar/inc/class.calendar_export_csv.inc.php&p1=trunk/addressbook/inc/class.addressbook_export_contacts_csv.inc.php&r1=32506&r2=32509&rev=32509&view=diff
— trunk/addressbook/inc/class.addressbook_export_contacts_csv.inc.php (original)
+++ trunk/calendar/inc/class.calendar_export_csv.inc.php Wed Oct 13 00:45:02 2010
@@ -3,18 +3,18 @@
- eGroupWare
- @license http://opensource.org/licenses/gpl-license.php GPL - GNU General Public License
- @package addressbook
- @package calendar
- @subpackage importexport
- @link http://www.egroupware.org
- @author Cornelius Weiss nelius@cwtech.de
- @copyright Cornelius Weiss nelius@cwtech.de
- @version $Id: $
- @author Nathan Gray
- @copyright Nathan Gray
@version $Id$
@version $Id$
- export plugin of addressbook
export CSV plugin of calendar
-class addressbook_export_contacts_csv implements importexport_iface_export_plugin {
+class calendar_export_csv implements importexport_iface_export_plugin {/**
- Exports records as defined in $_definition
@@ -23,32 +23,28 @@
public function export( $_stream, importexport_definition $_definition) {
$options = $_definition->plugin_options;
$uicontacts = new addressbook_ui(); -
$selection = array(); -
if ($options['selection'] == 'use_all') { -
// uicontacts selection with checkbox 'use_all' -
$query = $GLOBALS['egw']->session->appsession('index','addressbook'); -
$query['num_rows'] = -1; // all -
$uicontacts->get_rows($query,$selection,$readonlys,true); // true = only return the id's -
elseif ( $options['selection'] == 'all_contacts' ) { -
$selection = ExecMethod('addressbook.addressbook_bo.search',array()); -
//$uicontacts->get_rows($query,$selection,$readonlys,true); -
} else { -
$selection = explode(',',$options['selection']); -
$this->bo = new calendar_bo(); -
$events =& $this->bo->search(array( -
'start' => $options['selection']['start'], -
'end' => $options['selection']['end'], -
'categories' => $options['categories'] ? $options['categories'] : $options['selection']['categories'], -
'enum_recuring' => false, -
'daywise' => false, -
'owner' => $options['owner'], -
'date_format' => $options['date_format'], -
)); $export_object = new importexport_export_csv($_stream, (array)$options); $export_object->set_mapping($options['mapping']); // $options['selection'] is array of identifiers as this plugin doesn't // support other selectors atm.
foreach ($selection as $identifier) { -
$contact = new addressbook_egw_record($identifier); -
$export_object->export_record($contact); -
unset($contact);
$record = new calendar_egw_record(); -
foreach ($events as $event) { -
$record->set_record($event); -
$export_object->export_record($record); } -
unset($record);}
@@ -57,7 +53,7 @@-
@return string name
public static function get_name() {
@return string name
return lang('Addressbook CSV export');
return lang('Calendar CSV export');}
@@ -66,7 +62,7 @@-
@return string descriprion
public static function get_description() {
return lang("Exports contacts from your Addressbook into a CSV File.");
return lang("Exports events from your Calendar into a CSV File.");}
@@ -78,21 +74,28 @@
return ‘csv’;
- return html for options.
- this way the plugin has all opertunities for options tab
- @return string html
- public function get_options_etpl() {
return 'addressbook.export_csv_options';
public static function get_mimetype() {
return 'text/csv';}
- returns slectors of this plugin via xajax
- returns selectors of this plugin
public function get_selectors_etpl() {
return 'addressbook.export_csv_selectors';
return array( -
'name' => 'calendar.export_csv_select', -
'content' => array( -
'start' => time(), -
'end' => time() -
Copied: trunk/calendar/inc/class.calendar_wizard_export_csv.inc.php (from r32506, trunk/addressbook/inc/class.addressbook_wizard_export_contacts_csv.inc.php)
URL: http://www.egroupware.org/viewvc/egroupware/trunk/calendar/inc/class.calendar_wizard_export_csv.inc.php?p2=trunk/calendar/inc/class.calendar_wizard_export_csv.inc.php&p1=trunk/addressbook/inc/class.addressbook_wizard_export_contacts_csv.inc.php&r1=32506&r2=32509&rev=32509&view=diff
— trunk/addressbook/inc/class.addressbook_wizard_export_contacts_csv.inc.php (original)
+++ trunk/calendar/inc/class.calendar_wizard_export_csv.inc.php Wed Oct 13 00:45:02 2010
@@ -3,22 +3,25 @@
- eGroupWare - Wizard for Adressbook CSV export
- @package calendar
- @version $Id: $
@version $Id$
@version $Id$
-class addressbook_wizard_export_contacts_csv extends importexport_wizard_basic_export_csv
+class calendar_wizard_export_csv extends importexport_wizard_basic_export_csv
public function __construct() {
parent::__construct();
// Field mapping
$bocontacts = new addressbook_bo(); -
$this->export_fields = $bocontacts->contact_fields; -
foreach($bocontacts->customfields as $name => $data) {
$bo = new calendar_tracking(); -
$this->export_fields = $bo->field2label; -
$custom = config::get_customfields('calendar', true); -
foreach($custom as $name => $data) { $this->export_fields['#'.$name] = $data['label']; }
unset($this->export_fields['jpegphoto']); // can't cvs export that
Modified: trunk/calendar/setup/etemplates.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/calendar/setup/etemplates.inc.php?rev=32509&r1=32508&r2=32509&view=diff
— trunk/calendar/setup/etemplates.inc.php (original)
+++ trunk/calendar/setup/etemplates.inc.php Wed Oct 13 00:45:02 2010
@@ -2,7 +2,7 @@
* eGroupWare - eTemplates for Application calendar
* http://www.egroupware.org
- generated by soetemplate::dump4setup() 2010-10-07 08:23
- generated by soetemplate::dump4setup() 2010-10-12 16:44
@package calendar
@@ -45,6 +45,8 @@
$templ_data[] = array(‘name’ => ‘calendar.export’,‘template’ => ‘’,‘lang’ => ‘’,‘group’ => ‘0’,‘version’ => ‘1.0.1.001’,‘data’ => ‘a:1:{i:0;a:6:{s:4:“type”;s:4:“grid”;s:4:“data”;a:8:{i:0;a:2:{s:2:“h5”;s:2:",1";s:2:“h1”;s:6:",!@msg";}i:1;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“span”;s:11:“all,message”;s:4:“name”;s:3:“msg”;}s:1:“B”;a:1:{s:4:“type”;s:5:“label”;}}i:2;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“size”;s:8:",start";s:5:“label”;s:5:“Start”;}s:1:“B”;a:3:{s:4:“type”;s:4:“date”;s:4:“name”;s:5:“start”;s:4:“help”;s:23:“Startdate of the export”;}}i:3;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“size”;s:6:",end";s:5:“label”;s:3:“End”;}s:1:“B”;a:3:{s:4:“type”;s:4:“date”;s:4:“name”;s:3:“end”;s:4:“help”;s:21:“Enddate of the export”;}}i:4;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“size”;s:7:",file";s:5:“label”;s:8:“Filename”;}s:1:“B”;a:3:{s:4:“type”;s:4:“text”;s:4:“name”;s:4:“file”;s:4:“help”;s:24:“Filename of the download”;}}i:5;a:2:{s:1:“A”;a:3:{s:4:“type”;
s:5:“label”;s:4:“size”;s:10:",version";s:5:“label”;s:7:“Version”;}s:1:“B”;a:2:{s:4:“type”;s:6:“select”;s:4:“name”;s:7:“version”;}}i:6;a:2:{s:1:“A”;a:1:{s:4:“type”;s:5:“label”;}s:1:“B”;a:3:{s:4:“type”;s:6:“button”;s:5:“label”;s:8:“Download”;s:4:“name”;s:8:“download”;}}i:7;a:2:{s:1:“A”;a:2:{s:4:“type”;s:5:“label”;s:4:“span”;s:3:“all”;}s:1:“B”;a:1:{s:4:“type”;s:5:“label”;}}}s:4:“rows”;i:7;s:4:“cols”;i:2;s:5:“align”;s:6:“center”;s:7:“options”;a:0:{}}}’,‘size’ => ‘’,‘style’ => ‘’,‘modified’ => ‘1130738737’,);
+$templ_data[] = array(‘name’ => ‘calendar.export_csv_select’,‘template’ => ‘’,‘lang’ => ‘’,‘group’ => ‘0’,‘version’ => ‘1.9.001’,‘data’ => ‘a:1:{i:0;a:6:{s:4:“type”;s:4:“grid”;s:4:“data”;a:5:{i:0;a:1:{s:2:“h1”;s:6:",!@msg";}i:1;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“span”;s:11:“all,message”;s:4:“name”;s:3:“msg”;}s:1:“B”;a:1:{s:4:“type”;s:5:“label”;}}i:2;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“size”;s:8:",start";s:5:“label”;s:5:“Start”;}s:1:“B”;a:3:{s:4:“type”;s:4:“date”;s:4:“name”;s:16:“selection[start]”;s:4:“help”;s:23:“Startdate of the export”;}}i:3;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“size”;s:6:",end";s:5:“label”;s:3:“End”;}s:1:“B”;a:3:{s:4:“type”;s:4:“date”;s:4:“name”;s:14:“selection[end]”;s:4:“help”;s:21:“Enddate of the export”;}}i:4;a:2:{s:1:“A”;a:2:{s:4:“type”;s:5:“label”;s:4:“span”;s:3:“all”;}s:1:“B”;a:1:{s:4:“type”;s:5:“label”;}}}s:4:“rows”;i:4;s:4:“cols”;i:2;s:5:“align”;s:6:“center”;s:7:“options”;a:0:{}}}’,‘size’ => ‘’,‘style’ => ‘’,‘modif
ied’ => ‘1286919523’,);
$templ_data[] = array(‘name’ => ‘calendar.freetimesearch’,‘template’ => ‘’,‘lang’ => ‘’,‘group’ => ‘0’,‘version’ => ‘1.3.001’,‘data’ => ‘a:1:{i:0;a:4:{s:4:“type”;s:4:“grid”;s:4:“data”;a:7:{i:0;a:0:{}i:1;a:2:{s:1:“A”;a:3:{s:4:“type”;s:5:“label”;s:4:“span”;s:9:",size120b";s:5:“label”;s:15:“Freetime Search”;}s:1:“B”;a:4:{s:4:“type”;s:5:“label”;s:4:“span”;s:10:",redItalic";s:7:“no_lang”;s:1:“1”;s:4:“name”;s:3:“msg”;}}i:2;a:2:{s:1:“A”;a:2:{s:4:“type”;s:5:“label”;s:5:“label”;s:17:“Startdate / -time”;}s:1:“B”;a:3:{s:4:“type”;s:9:“date-time”;s:4:“name”;s:5:“start”;s:4:“help”;s:33:“Startdate and -time of the search”;}}i:3;a:2:{s:1:“A”;a:2:{s:4:“type”;s:5:“label”;s:5:“label”;s:8:“Duration”;}s:1:“B”;a:4:{s:4:“type”;s:4:“hbox”;s:4:“size”;s:1:“2”;i:1;a:6:{s:4:“type”;s:6:“select”;s:7:“no_lang”;s:1:“1”;s:4:“name”;s:8:“duration”;s:4:“help”;s:23:“Duration of the meeting”;s:8:“onchange”;s:92:“set_style_by_class(‘table’,‘end_hide’,‘visibility’,this.value == ‘’ ? ‘visible’ : ‘hidden
’);”;s:4:“size”;s:12:“Use end date”;}i:2;a:4:{s:4:“type”;s:9:“date-time”;s:4:“name”;s:3:“end”;s:4:“help”;s:57:“Enddate / -time of the meeting, eg. for more then one day”;s:4:“span”;s:9:",end_hide";}}}i:4;a:2:{s:1:“A”;a:2:{s:4:“type”;s:5:“label”;s:5:“label”;s:9:“Timeframe”;}s:1:“B”;a:7:{s:4:“type”;s:4:“hbox”;s:4:“size”;s:1:“5”;i:1;a:3:{s:4:“type”;s:13:“date-houronly”;s:4:“name”;s:10:“start_time”;s:4:“help”;s:19:“Timeframe to search”;}i:2;a:2:{s:4:“type”;s:5:“label”;s:5:“label”;s:3:“til”;}i:3;a:3:{s:4:“type”;s:13:“date-houronly”;s:4:“name”;s:8:“end_time”;s:4:“help”;s:19:“Timeframe to search”;}i:4;a:2:{s:4:“type”;s:5:“label”;s:5:“label”;s:8:“Weekdays”;}i:5;a:4:{s:4:“type”;s:10:“select-dow”;s:4:“size”;s:1:“3”;s:4:“name”;s:8:“weekdays”;s:4:“help”;s:25:“Weekdays to use in search”;}}}i:5;a:2:{s:1:“A”;a:4:{s:4:“type”;s:6:“button”;s:5:“label”;s:10:“New search”;s:4:“name”;s:6:“search”;s:4:“help”;s:36:“new search with the above parameters”;}s:1:“B”;a:4:{s:4:“type”;s:4:“hbox”;s:4:“size”
;s:1:“2”;i:1;a:4:{s:4:“type”;s:6:“select”;s:7:“no_lang”;s:1:“1”;s:4:“name”;s:13:“search_window”;s:4:“help”;s:34:“how far to search (from startdate)”;}i:2;a:5:{s:4:“type”;s:6:“button”;s:4:“name”;s:6:“cancel”;s:5:“label”;s:6:“Cancel”;s:4:“help”;s:16:“Close the window”;s:7:“onclick”;s:15:“window.close();”;}}}i:6;a:2:{s:1:“A”;a:4:{s:4:“type”;s:8:“template”;s:4:“size”;s:8:“freetime”;s:4:“span”;s:3:“all”;s:4:“name”;s:4:“rows”;}s:1:“B”;a:1:{s:4:“type”;s:5:“label”;}}}s:4:“rows”;i:6;s:4:“cols”;i:2;}}’,‘size’ => ‘’,‘style’ => ‘.size120b { text-size: 120%; font-weight: bold; }
.redItalic { color: red; font-style: italic; }
.end_hide { visibility: hidden; }’,‘modified’ => ‘1149297367’,);
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
eGroupWare-cvs mailing list
