Author: ralfbecker
New Revision: 32563
URL: http://www.egroupware.org/viewvc/egroupware?rev=32563&view=rev
only provide old pathes for old functionality, new code can use new path dhtmlxTree/codebase
Removed:
trunk/phpgwapi/js/dhtmlxtree/js/ext/
trunk/phpgwapi/js/dhtmlxtree/readme.EGroupware.txt
Modified: trunk/phpgwapi/js/dhtmlxtree/readme.EGroupware.txt
URL: http://www.egroupware.org/viewvc/egroupware/trunk/phpgwapi/js/dhtmlxtree/readme.EGroupware.txt?rev=32563&r1=32562&r2=32563&view=diff
— trunk/phpgwapi/js/dhtmlxtree/readme.EGroupware.txt (original)
+++ trunk/phpgwapi/js/dhtmlxtree/readme.EGroupware.txt Fri Oct 15 18:16:07 2010
@@ -3,12 +3,11 @@
± css
± dhtmlxtree.css --> dhtmlxTree/codebase/dhtmlxtree.css
± js
± dhtmlxcommon.js --> dhtmlxTree/codebase/dhtmlcommon.js
± dhtmlxtree.js --> dhtmlxTree/codebase/dhtmlxtree.js
- ± ext --> dhtmlxTree/codebase/ext
-These files/directories are copied from dhtmlxTree/codebase to not modify all code.
+These files/directories are copied from dhtmlxTree/codebase to not modify old code.
If dhtmlxtree get updated, these files have to be copied again, or code need to be changed.
Download new Adobe® Flash® Builder™ 4
The new Adobe® Flex® 4 and Flash® Builder™ 4 (formerly
Flex® Builder™) enable the development of rich applications that run
across multiple browsers and platforms. Download your free trials today!
http://p.sf.net/sfu/adobe-dev2dev
eGroupWare-cvs mailing list
