Author: leithoff
New Revision: 34467
URL: http://www.egroupware.org/viewvc/egroupware?rev=34467&view=rev
- addressbook: enable Advanced Search for OrgView
trunk/addressbook/inc/class.addressbook_sql.inc.php
trunk/addressbook/inc/class.addressbook_ui.inc.php
Modified: trunk/addressbook/inc/class.addressbook_sql.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/addressbook/inc/class.addressbook_sql.inc.php?rev=34467&r1=34466&r2=34467&view=diff
— trunk/addressbook/inc/class.addressbook_sql.inc.php (original)
+++ trunk/addressbook/inc/class.addressbook_sql.inc.php Wed Mar 30 15:31:09 2011
@@ -91,6 +91,9 @@
* @var string $param[searchletter] letter the org_name need to start with
* @var array $param[col_filter] filter
* @var string $param[search] or’ed search pattern
- @var array $param[advanced_search] indicator that advanced search is active
- @var string $param[op] (operator like AND or OR; will be passed when advanced search is active)
- @var string $param[wildcard] (wildcard like % or empty or not set (for no wildcard); will be passed when advanced search is active)
- @var int $param[start]
- @var int $param[num_rows]
@var string $param[sort] ASC or DESC
@@ -99,7 +102,13 @@
function organisations($param)
$filter = is_array($param[‘col_filter’]) ? $param[‘col_filter’] : array();
$op = 'OR'; -
if (isset($param['op']) && !empty($param['op'])) $op = $param['op']; -
$advanced_search = false; -
if (isset($param['advanced_search']) && !empty($param['advanced_search'])) $advanced_search = true; -
$wildcard ='%'; -
if ($advanced_search || (isset($param['wildcard']) && !empty($param['wildcard']))) $wildcard = ($param['wildcard']?$param['wildcard']:''); -
// fix cat_id filter to search in comma-separated multiple cats and return subcats if ((int)$filter['cat_id']) {
@@ -164,7 +173,7 @@
‘COUNT(DISTINCT egw_addressbook.contact_id) AS org_count’,
“COUNT(DISTINCT CASE WHEN org_unit IS NULL THEN ‘’ ELSE org_unit END) AS org_unit_count”,
“COUNT(DISTINCT CASE WHEN adr_one_locality IS NULL THEN ‘’ ELSE adr_one_locality END) AS adr_one_locality_count”,
),'%',false,'OR','UNION',$filter);
),$wildcard,false,$op/*'OR'*/,'UNION',$filter); // org by location $append = "GROUP BY org_name,$by ORDER BY org_name $sort,$by $sort"; parent::search($param['search'],array('org_name'),$append,array(
@@ -173,10 +182,10 @@
),$wildcard,false,$op/*'OR'*/,'UNION',$filter); $append = "ORDER BY org_name $sort,is_main DESC,$by $sort"; }
$rows = parent::search($param['search'],array('org_name'),$append,$extra,'%',false,'OR',
$rows = parent::search($param['search'],array('org_name'),$append,$extra,$wildcard,false,$op/*'OR'*/, array($param['start'],$param['num_rows']),$filter); if (!$rows) return false;
@@ -197,7 +206,7 @@
if (count($filter[‘org_name’]))
foreach((array) parent::search($criteria,array(‘org_name’,‘org_unit’,‘adr_one_locality’),‘GROUP BY org_name,org_unit,adr_one_locality’,
'','%',false,'AND',false,$filter) as $row)
'',$wildcard,false,$op/*'AND'*/,false,$filter) as $row) { $org_key = $row['org_name'].($by ? '|||'.$row[$by] : ''); if ($orgs[$org_key]['org_unit_count'] == 1)
Modified: trunk/addressbook/inc/class.addressbook_ui.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/addressbook/inc/class.addressbook_ui.inc.php?rev=34467&r1=34466&r2=34467&view=diff
— trunk/addressbook/inc/class.addressbook_ui.inc.php (original)
+++ trunk/addressbook/inc/class.addressbook_ui.inc.php Wed Mar 30 15:31:09 2011
@@ -852,9 +852,10 @@
if (isset($this->org_views[(string) $query[‘org_view’]])) // we have an org view, reset the advanced search
//_debug_array(array(‘Search’=>$query[‘search’],
//'AdvancedSearch'=>$query['advanced_search'])); -
if (is_array($query['search'])) unset($query['search']); -
unset($query['advanced_search']);
// 'AdvancedSearch'=>$query['advanced_search'])); -
//if (is_array($query['search'])) unset($query['search']); -
//unset($query['advanced_search']); -
if(!$query['search'] && $old_state['advanced_search']) $query['advanced_search'] = $old_state['advanced_search']; } elseif(!$query['search'] && $old_state['advanced_search']) // eg. paging in an advanced search {
@@ -945,8 +946,23 @@
$query[‘sort’] = ‘ASC’;
$query[‘order’] = ‘org_name’;
if ($query['advanced_search']) -
$query['op'] = $query['advanced_search']['operator']; -
unset($query['advanced_search']['operator']); -
$query['wildcard'] = $query['advanced_search']['meth_select']; -
unset($query['advanced_search']['meth_select']); -
$original_search = $query['search']; -
$query['search'] = $query['advanced_search']; -
$rows = parent::organisations($query);
$query['search'] = $original_search; -
unset($query['wildcard']); -
unset($query['op']); -
} $GLOBALS['egw_info']['flags']['params']['manual'] = array('page' => 'ManualAddressbookIndexOrga'); } else // contacts view
@@ -1211,7 +1227,7 @@
$order = $order == ‘n_given’ ? lang(‘first name’) : ($order == ‘n_family’ ? lang(‘last name’) : lang(‘Organisation’));
$GLOBALS[‘egw_info’][‘flags’][‘app_header’] .= ’ - '.lang("%1 starts with ‘%2’",$order,$query[‘searchletter’]);
if ($query['search'])
if ($query['search'] && !$query['advanced_search']) // do not add that, if we have advanced search active { $GLOBALS['egw_info']['flags']['app_header'] .= ' - '.lang("Search for '%1'",$query['search']); }
Enable your software for Intel® Active Management Technology to meet the
growing manageability and security demands of your customers. Businesses
are taking advantage of Intel® vPro ™ technology - will your software
be a part of the solution? Download the Intel® Manageability Checker
today! http://p.sf.net/sfu/intel-dev2devmar
eGroupWare-cvs mailing list
