R34614 - /branches/1.8/addressbook/inc/class.addressbook_sql.inc.php
Author: ralfbecker
New Revision: 34614
URL: http://www.egroupware.org/viewvc/egroupware?rev=34614&view=rev
  • SyncML/Calendar/PostgreSQL: fixed SQL error when searching participants (SELECT DISTINCT requires ORDER-BY-expressions to be in SELECT-list)
Modified: branches/1.8/addressbook/inc/class.addressbook_sql.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/branches/1.8/addressbook/inc/class.addressbook_sql.inc.php?rev=34614&r1=34613&r2=34614&view=diff
— branches/1.8/addressbook/inc/class.addressbook_sql.inc.php (original)
+++ branches/1.8/addressbook/inc/class.addressbook_sql.inc.php Mon Apr 11 14:10:23 2011
@@ -432,17 +432,25 @@
break;
// postgres requires that expressions in order by appear in the columns of a distinct select
  •   	if ($this->db->Type != 'mysql' && preg_match("/([a-zA-Z_.]+)<>''/",$order_by,$matches))
  •   	if ($this->db->Type != 'mysql' && preg_match_all("/([a-zA-Z_.]+) *(<> *''|IS NULL|IS NOT NULL)/u",$order_by,$all_matches,PREG_SET_ORDER))
      		if (!is_array($extra_cols))	$extra_cols = $extra_cols ? explode(',',$extra_cols) : array();
  •   		$extra_cols[] = $matches[1];
  •   		$extra_cols[] = $matches[1]."<>''";
  •   		//_debug_array($matches[1]);
  •   		if (!empty($order_by) && $matches[1] != 'extra_order.contact_value' && stripos($matches[1],'.')===false) // postgres requires explizit order by
  •   			$order_by = str_replace($matches[1],'egw_addressbook.'.$matches[1],$order_by);
  •   		//_debug_array($order_by);
  •   		foreach($all_matches as $matches)
  •   			$table = '';
  •   			if (strpos($matches[1],'.') === false)
  •   				$table = ($matches[1] == $this->extra_value ? $this->extra_table : $this->table_name).'.';
  •   			$extra_cols[] = $table.$matches[1];
  •   			$extra_cols[] = $table.$matches[0];
  •   			//_debug_array($matches);
  •   			if (!empty($order_by) && $table) // postgres requires explizit order by
  •   				$order_by = str_replace($matches[0],$table.$matches[0],$order_by);
  •   		//_debug_array($order_by); _debug_array($extra_cols);
      // add join to show only active accounts (only if accounts are shown and in sql and we not already join the accounts table, eg. used by admin)
Xperia™ PLAY
It’s a major breakthrough. An authentic gaming
smartphone on the nation’s most reliable network.
And it wants your games.
http://p.sf.net/sfu/verizon-sfdev
eGroupWare-cvs mailing list
