R34819 - in /trunk/infolog: inc/ js/ lang/ setup/ templates/default/ templates/default/images/
Author: ralfbecker
New Revision: 34819
URL: http://www.egroupware.org/viewvc/egroupware?rev=34819&view=rev
Context menu for InfoLog: NOT YET COMPLETET, SOME STUFF WILL NOT WORK!
ToDo:
  • implement view subs or parent from context
  • test all context actions (some do not work)
  • test CSS based disabling of actions
  • change delegation or links popup not yet working (just an alert in index.js)
  • delete of entries with subs (serverside confirmation displaying subs) probably not working
Added:
trunk/infolog/templates/default/images/completed.png (with props)
trunk/infolog/inc/class.infolog_bo.inc.php
trunk/infolog/inc/class.infolog_ui.inc.php
trunk/infolog/js/index.js
trunk/infolog/lang/egw_bg.lang
trunk/infolog/lang/egw_ca.lang
trunk/infolog/lang/egw_cs.lang
trunk/infolog/lang/egw_da.lang
trunk/infolog/lang/egw_de.lang
trunk/infolog/lang/egw_el.lang
trunk/infolog/lang/egw_en.lang
trunk/infolog/lang/egw_es-es.lang
trunk/infolog/lang/egw_et.lang
trunk/infolog/lang/egw_eu.lang
trunk/infolog/lang/egw_fa.lang
trunk/infolog/lang/egw_fi.lang
trunk/infolog/lang/egw_fr.lang
trunk/infolog/lang/egw_hr.lang
trunk/infolog/lang/egw_hu.lang
trunk/infolog/lang/egw_id.lang
trunk/infolog/lang/egw_it.lang
trunk/infolog/lang/egw_iw.lang
trunk/infolog/lang/egw_ko.lang
trunk/infolog/lang/egw_lv.lang
trunk/infolog/lang/egw_nl.lang
trunk/infolog/lang/egw_no.lang
trunk/infolog/lang/egw_pl.lang
trunk/infolog/lang/egw_pt-br.lang
trunk/infolog/lang/egw_pt.lang
trunk/infolog/lang/egw_ru.lang
trunk/infolog/lang/egw_sk.lang
trunk/infolog/lang/egw_sl.lang
trunk/infolog/lang/egw_sv.lang
trunk/infolog/lang/egw_tr.lang
trunk/infolog/lang/egw_uk.lang
trunk/infolog/lang/egw_zh-tw.lang
trunk/infolog/lang/egw_zh.lang
trunk/infolog/setup/etemplates.inc.php
trunk/infolog/templates/default/index.xet
Modified: trunk/infolog/inc/class.infolog_bo.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/infolog/inc/class.infolog_bo.inc.php?rev=34819&r1=34818&r2=34819&view=diff
— trunk/infolog/inc/class.infolog_bo.inc.php (original)
+++ trunk/infolog/inc/class.infolog_bo.inc.php Mon May 2 21:41:21 2011
@@ -128,7 +128,7 @@
‘own-open-overdue’ => ‘own overdue’,
‘own-upcoming’ => ‘own upcoming’,
‘own-open-upcoming’ => ‘own open and upcoming’,
  •   'open-today'               => 'open',
  •   'open-today'               => 'open(status)',
      'open-overdue'             => 'overdue',
      'upcoming'                 => 'upcoming',
      'open-upcoming'			   => 'open and upcoming',
Modified: trunk/infolog/inc/class.infolog_ui.inc.php
URL: http://www.egroupware.org/viewvc/egroupware/trunk/infolog/inc/class.infolog_ui.inc.php?rev=34819&r1=34818&r2=34819&view=diff
— trunk/infolog/inc/class.infolog_ui.inc.php (original)
+++ trunk/infolog/inc/class.infolog_ui.inc.php Mon May 2 21:41:21 2011
@@ -91,7 +91,7 @@
function __construct()
  •   if ($GLOBALS['egw_info']['flags']['currentapp'] != 'infolog') $GLOBALS['egw']->translation->add_app('infolog');
  •   if ($GLOBALS['egw_info']['flags']['currentapp'] != 'infolog') translation::add_app('infolog');
      $this->bo = new infolog_bo();
      $this->tmpl = new etemplate();
@@ -161,8 +161,11 @@
$info[‘info_percent’] = (int) $info[‘info_percent’].’%’;
$editrights = $this->bo->check_access($info,EGW_ACL_EDIT);
$isresposible = $this->bo->is_responsible($info);
  •   $readonlys["edit[$id]"] = !($editrights || // edit rights or more then standard responsible rights
  •   	$isresposible && array_diff($this->bo->responsible_edit,array('info_status','info_percent','info_datecompleted')));
  •   if (($readonlys["edit[$id]"] = !($editrights || // edit rights or more then standard responsible rights
  •   	$isresposible && array_diff($this->bo->responsible_edit,array('info_status','info_percent','info_datecompleted')))))
  •   	$info['class'] .= 'rowNoEdit ';
      $readonlys["close[$id]"] = $done || ($readonlys["edit_status[$id]"] =
      	!($editrights || $isresposible));
      $readonlys["close_all[$id]"] = ($done) || !$info['info_anz_subs'] || ($readonlys["edit_status[$id]"] =
@@ -172,11 +175,21 @@
$readonlys[“edit_status[$id]”] = $readonlys[“edit_percent[$id]”] =
!$editrights && !$isresposible &&
!$this->bo->check_access($info,EGW_ACL_UNDELETE); // undelete is handled like status edit
  •   $readonlys["delete[$id]"] = !$this->bo->check_access($info,EGW_ACL_DELETE);
  •   $readonlys["sp[$id]"] = !$this->bo->check_access($info,EGW_ACL_ADD);
  •   if (($readonlys["delete[$id]"] = !$this->bo->check_access($info,EGW_ACL_DELETE)))
  •   	$info['class'] .= 'rowNoDelete ';
  •   if (($readonlys["sp[$id]"] = !$this->bo->check_access($info,EGW_ACL_ADD)))
  •   	$info['class'] .= 'rowNoSubs ';
  •   if ($info['info_id_parent']) $info['class'] .= 'rowHasParent ';
  •   if ($info['info_anz_subs'] > 0) $info['class'] .= 'rowHasSubs ';
  •   $readonlys["view[$id]"] = $info['info_anz_subs'] < 1;
      $readonlys['view[0]'] = True;	// no parent
      $readonlys["timesheet[$id]"] = !isset($GLOBALS['egw_info']['user']['apps']['timesheet']);
  •   $readonlys["document[$id]"] = !$this->prefs['default_document'];
      if (!$show_links) $show_links = $this->prefs['show_links'];
      if (($show_links != 'none' && $show_links != 'no_describtion' ||
@@ -231,56 +244,6 @@
$info[‘info_number’] = $info[‘info_id’];
return $info;
    • Saves state of the infolog list in the session
    • @param array $values
  • function save_sessiondata($values)
  •   $for = @$values['session_for'] ? $values['session_for'] : @$this->called_by;
  •   //echo "<p>$for: ".__METHOD__.'('.print_r($values,True).") called_by='$this->called_by', for='$for'<br />".function_backtrace()."</p>\n";
  •   $arrayToStore = array(
  •   	'search' => $values['search'],
  •   	'start'  => $values['start'],
  •   	'num_rows' => $values['num_rows'],
  •   	'filter' => $values['filter'],
  •   	'filter2' => $values['filter2'],
  •   	'cat_id' => $values['cat_id'],
  •   	'order'  => $values['order'],
  •   	'sort'   => $values['sort'],
  •   	'action' => $values['action'],
  •   	'action_id' => $values['action_id'],
  •   	'action_title' => $values['action_title'],
  •   	'col_filter' => $values['col_filter'],
  •   	'session_for' => $for
  •   if ($values['filter']=='bydate')
  •   	$arrayToStore['startdate'] = $values['startdate'];
  •   	$arrayToStore['enddate'] = $values['enddate'];
  •   $GLOBALS['egw']->session->appsession($for.'session_data','infolog',$arrayToStore);
    • reads list-state from the session
    • @return array
  • function read_sessiondata()
  •   $values = $GLOBALS['egw']->session->appsession(@$this->called_by.'session_data','infolog');
  •   if (!@$values['session_for'] && $this->called_by)
  •   	$values['session_for'] = $this->called_by;
  •   	$this->save_sessiondata($values);
  •   //echo "<p>called_by='$this->called_by': ".__METHOD__."() = ".print_r($values,True)."</p>\n";
  •   return $values;
    @@ -293,6 +256,11 @@
    function get_rows(&$query,&$rows,&$readonlys)
  •   if (!$query['csv_export'])
  •   	egw_cache::setSession('infolog', $query['session_for'].'session_data', $query);
  •   	$query['actions'] = $this->get_actions($query);
      $orginal_colfilter = $query['col_filter'];
      if ($query['filter'] == 'bydate')
@@ -300,8 +268,6 @@
$GLOBALS[‘egw’]->js->set_onload(“set_style_by_class(‘table’,‘custom_hide’,‘visibility’,‘visible’);”);
if (is_int($query[‘startdate’])) $query[‘col_filter’][] = 'info_startdate >= '.$GLOBALS[‘egw’]->db->quote($query[‘startdate’]);
if (is_int($query[‘enddate’])) $query[‘col_filter’][] = 'info_startdate <= '.$GLOBALS[‘egw’]->db->quote($query[‘enddate’]+(606024)-1);
  •   	//unset($query['startdate']);
  •   	//unset($query['enddate']);
      else
@@ -309,17 +275,11 @@
unset($query[‘startdate’]);
unset($query[‘enddate’]);
-//_debug_array($query);
-//_debug_array($query[‘col_filter’]);
	//echo "<p>infolog_ui.get_rows(start=$query[start],search='$query[search]',filter='$query[filter]',cat_id=$query[cat_id],action='$query[action]/$query[action_id]',col_filter=".print_r($query['col_filter'],True).",sort=$query[sort],order=$query[order])</p>\n";
	if (!isset($query['start'])) $query['start'] = 0;
  •   	$this->save_sessiondata($query);
  •   else
  •   if ($query['csv_export'])
      	$query['csv_fields'] = $this->csv_export_fields($query['col_filter']['info_type']);
@@ -412,9 +372,15 @@
$rows[] = $info;
  •   	$readonlys["document[{$info['info_id']}]"] = !$this->prefs['default_document'];
      unset($links);
  •   if ($query['action'] == 'sp' && ($main = $this->bo->read($query['action_id'])))
  •   	$main = $this->get_info($main, $readonlys);
  •   	$main['class'] .= 'th ';
  •   	array_unshift($rows, $main);
      if ($query['cat_id']) $rows['no_cat_id'] = true;
      if ($query['no_actions']) $rows['no_actions'] = true;
@@ -459,7 +425,7 @@
$GLOBALS[‘egw_info’][‘flags’][‘app_header’] .= ’ - '.lang($this->filters[$query[‘filter’]]);
  •   	if ($query['action'] && ($title = $query['action_title'] ? $query['action_title'] : egw_link::title($query['action'],$query['action_id'])))
  •   	if ($query['action'] && ($title = $query['action_title'] ? $query['action_title'] : egw_link::title($query['action']=='sp'?'infolog':$query['action'],$query['action_id'])))
      		$GLOBALS['egw_info']['flags']['app_header'] .= ': '.$title;
@@ -507,23 +473,23 @@
if (is_array($values) && isset($values[‘nm’][‘rows’][‘document’])) // handle insert in default document button like an action
list($id) = @each($values[‘nm’][‘rows’][‘document’]);
  •   	$values['multi_action'] = 'document';
  •   	$values['nm']['rows']['checked'] = array($id);
  •   if (is_array($values) && isset($values['multi_action']) && $values['multi_action'] !== '')
  •   	if (!count($values['nm']['rows']['checked']) && !$values['use_all'])
  •   	$values['nm']['action'] = 'document';
  •   	$values['nm']['selected'] = array($id);
  •   if (is_array($values) && !empty($values['nm']['action']))
  •   	if (!count($values['nm']['selected']) && !$values['nm']['select_all'])
      		$msg = lang('You need to select some entries first');
      	else
      		// Some processing to add values in for links and cats
  •   		$multi_action = $values['multi_action'];
  •   		$multi_action = $values['nm']['action'];
      		// Action has an additional action - add / delete, etc.  Buttons named <multi-action>_action[action_name]
      		if(in_array($multi_action, array('link', 'responsible')))
  •   			$values['multi_action'] .= '_' . key($values[$multi_action . '_action']);
  •   			$values['nm']['action'] .= '_' . key($values[$multi_action . '_action']);
      		// Action has a parameter - cat_id, percent, etc
      		if (in_array($multi_action, array('link', 'cat', 'completion', 'responsible')))
@@ -532,10 +498,10 @@
$values[$multi_action] = implode(’,’,$values[$multi_action]);
  •   			$values['multi_action'] .= '_' . $values[$multi_action];
  •   		if ($this->action($values['multi_action'],$values['nm']['rows']['checked'],$values['use_all'],
  •   			$success,$failed,$action_msg,false,$msg, $values['no_notifications']))
  •   			$values['nm']['action'] .= '_' . $values[$multi_action];
  •   		if ($this->action($values['nm']['action'], $values['nm']['selected'], $values['nm']['select_all'],
  •   			$success, $failed, $action_msg, $values['nm'], $msg, $values['nm']['checkboxes']['no_notifications']))
      			$msg .= lang('%1 entries %2',$success,$action_msg);
@@ -543,42 +509,29 @@
$msg .= lang(’%1 entries %2, %3 failed because of insufficent rights !!!’,$success,$action_msg,$failed);
  •   		unset($values['multi_action']);
  •   		unset($values['use_all']);
  •   		unset($values['nm']['action']);
  •   		unset($values['nm']['select_all']);
      	$values['msg'] = $msg;
  •   if(isset($values['nm']['rows'])) unset($values['nm']['rows']['checked']); // Can cause problems lower, no longer needed
      if (!$action)
      	$action = $values['action'] ? $values['action'] : get_var('action',array('POST','GET'));
      	$action_id = $values['action_id'] ? $values['action_id'] : get_var('action_id',array('POST','GET'));
      	$action_title = $values['action_title'] ? $values['action_title'] : get_var('action_title',array('POST','GET'));
  •   	if ($values === 'reset_action_view')	// only read action from session, if not called by index.php
  •   		$session = $this->read_sessiondata();
  •   		$session['action'] = $action = '';
  •   		$session['action_id'] = $action_id = 0;
  •   		$session['action_title'] = $action_title = '';
  •   		$this->save_sessiondata($session);
  •   		unset($session);
  •   	elseif (!$action)
  •   		$action = $session['action'];
  •   		$action_id = $session['action_id'];
  •   		$action_title = $session['action_title'];
  •   		// no action -> try to restore the previous colfilter
  •   		$colfilter = $session['col_filter'];
  •   		unset($session);
      //echo "<p>".__METHOD__."(action='$action/$action_id',called_as='$called_as/$values[referer]',own_referer='$own_referer') values=\n"; _debug_array($values);
      if (!is_array($values))
  •   	$values = array('nm' => $this->read_sessiondata());
  •   	$nm = egw_cache::getSession('infolog', $this->called_by.'session_data');
  •   		$nm['action'] = $action = '';
  •   		$nm['action_id'] = $action_id = 0;
  •   		$nm['action_title'] = $action_title = '';
  •   	$values = array('nm' => $nm);
  •   	if (isset($_GET['filter']) && $_GET['filter'] != 'default' || !isset($values['nm']['filter']) && !$this->called_by)
      		$values['nm']['filter'] = $_GET['filter'] && $_GET['filter'] != 'default' ? $_GET['filter'] :
@@ -588,19 +541,25 @@
$values[‘nm’][‘order’] = ‘info_datemodified’;
$values[‘nm’][‘sort’] = ‘DESC’;
  •   		$values['nm']['row_id'] = 'info_id';
  •   	if (!$values['nm']['session_for'] && $this->called_by) $values['nm']['session_for'] = $this->called_by;
  •   	$values['msg'] = $_GET['msg'];
      	$values['action'] = $action;
      	$values['action_id'] = $action_id;
  •   if($_GET['search']) {
  •   	$values['nm']['search'] = $_GET['search'];
  •   	$values['action_title'] = $action_title;
  •   if($_GET['search']) $values['nm']['search'] = $_GET['search'];
  •   if ($values['nm']['add'])
      	$values['add'] = $values['nm']['add'];
      	unset($values['nm']['add']);
  •   unset($values['nm']['rows']['checked']);	// not longer used, but hides button actions
  •   if ($values['add'] || $values['cancel'] || isset($values['nm']['rows']) || isset($values['main']))
      	if ($values['add'])
@@ -610,10 +569,9 @@
elseif ($values[‘cancel’] && $own_referer)
  •   		unset($session['action']);
  •   		unset($session['action_id']);
  •   		unset($values['nm']['action_id']);
  •   		egw_cache::setSession('infolog', $values['nm']['session_for'].'session_data', $values['nm']);
      		$this->tmpl->location($own_referer);
      	else
@@ -621,11 +579,9 @@
list($do,$do_id) = isset($values[‘main’]) ? each($values[‘main’]) : @each($values[‘nm’][‘rows’]);
list($do_id) = @each($do_id);
//echo “
infolog::index: do=’$do/$do_id’, referer=”; _debug_array($called_as);
+// todo: move this to actions(), interactive delete only if subs
switch($do)
  •   			case 'edit':
  •   			case 'edit_status':
  •   				return $this->edit($do_id,$action,$action_id,'',$called_as);
      			case 'delete':
      				if (!($values['msg'] = $this->delete($do_id,$called_as,$called_as ? '' : 'index'))) return;
      				// did we deleted the entries, whos subentries we are showing?
@@ -647,8 +603,6 @@
case ‘close_all’:
$this->close($do_id,$called_as,$closesingle);
break;
  •   			case 'sp':
  •   				return $this->edit(0,'sp',$do_id,'',$called_as);
      			case 'view':
      				$value = array();
      				$action = 'sp';
@@ -671,7 +625,6 @@
$action_id = 0;
break;
  •   		$values['main'][1] = $this->get_info($action_id,$readonlys['main']);
      		break;
      $readonlys['cancel'] = $action != 'sp';
@@ -724,10 +677,11 @@
$persist[‘called_as’] = $called_as;
$persist[‘own_referer’] = $own_referer;
$values[‘nm’][‘csv_fields’] = true; // get set in get_rows to not include all custom fields
  •   $persist['nm'] = array(
  •   	'sort' => $values['nm']['sort'],
  •   	'order' => $values['nm']['order'],
  •   // store whole $values[nm] in etemplate request
  •   unset($values['nm']['rows']);
  •   $persist['nm'] = $values['nm'];
  •   if (!$called_as)
      	$GLOBALS['egw_info']['flags']['params']['manual'] = array('page' => 'ManualInfologIndex');
@@ -748,22 +702,25 @@
$sel_options = array(
‘info_type’ => $this->bo->enums[‘type’],
‘pm_id’ => array(lang(‘No project’)),
  •   	'multi_action'	=> array(
  •   		'close'		=> lang('Close'),
  •   		'delete'	=> lang('Delete'),
  •   		'cat'		=> lang('Change category'),
  •   		'link'		=> lang('Add or delete links'),
  •   		'completion'	=> lang('Change completion'),
  •   		'responsible'	=> lang('Change responsible'),
  •   // Add in multi-infolog actions
  •   egw_framework::validate_file('.','index','infolog');
  •   return $this->tmpl->exec('infolog.infolog_ui.index',$values,$sel_options,$readonlys,$persist,$return_html ? -1 : 0);
    • Get actions / context menu items
    • @param array $query
    • @return array see nextmatch_widget::get_actions()
  • private function get_actions(array $query)
  •   for($i = 0; $i <= 100; $i += 10) $percent[$i] = $i.'%';
  •   // Types
  •   foreach($this->bo->enums['type'] as $type => $label)
  •   	$types['type_'.$type] = $label;
  •   $types = $this->bo->enums['type'];
      if ($this->bo->group_owners)
      	// remove types owned by groups the user has no edit grant
@@ -771,41 +728,204 @@
if (!($this->bo->grants[$group] & EGW_ACL_EDIT))
  •   			unset($types['type_'.$type]);
  •   $sel_options['multi_action'][lang('Change type:')] = $types;
  •   			unset($types[$type]);
  •   $types_add = array();
  •   foreach($types as $type => &$data)
  •   	$data = array(
  •   		'caption' => $data,
  •   		'icon' => $type,
  •   	$types_add[$type] = $data + array(
  •   		'url' => 'menuaction=infolog.infolog_ui.edit&type='.$type,
  •   		'popup' => egw_link::get_registry('infolog', 'add_popup'),
      // if filtered by type, show only the stati of the filtered type
  •   if ($values['nm']['col_filter']['info_type'] && isset($this->bo->status[$values['nm']['col_filter']['info_type']]))
  •   	$statis = $this->bo->status[$values['nm']['col_filter']['info_type']];
  •   if ($query['col_filter']['info_type'] && isset($this->bo->status[$query['col_filter']['info_type']]))
  •   	$statis = $this->bo->status[$query['col_filter']['info_type']];
      else	// show all stati
      	$statis = array();
  •   	foreach($this->bo->status as $typ => $stati)
  •   		if($typ == 'defaults') continue;
  •   	foreach($this->bo->status as $type => $stati)
  •   		if ($type == 'defaults') continue;
      		$statis += $stati;
      	$statis = array_unique($statis);
  •   foreach($statis as $id => $label)
  •   	$change_status['status_'.$id] = $label;
  •   $sel_options['multi_action'][lang('Change status:')] = $change_status;
  •   // Merge print
  •   if ($this->prefs['document_dir'])
  •   	$sel_options['multi_action'][lang('Insert in document').':'] = $this->get_document_actions();
  •   foreach($statis as $type => &$data)
  •   	$data = array(
  •   		'icon' => $type,
  •   $actions = array(
  •   	'open' => array(
  •   		'caption' => 'Open',
  •   		'default' => true,
  •   		'allowOnMultiple' => false,
  •   		'url' => 'menuaction=infolog.infolog_ui.edit&info_id=$id',
  •   		'group' => $group=1,
  •   	'sp' => array(
  •   		'caption' => 'View subs',
  •   		'icon' => 'view',
  •   		'group' => $group,
  •   		'hint' => 'View all subs of this entry',
  •   		'enableClass' => 'rowHasSubs',
  •   	'parent' => array(
  •   		'caption' => 'View parent',
  •   		'icon' => 'parent',
  •   		'hideOnDisabled' => true,
  •   		'hint' => 'View the parent of this entry and all his subs',
  •   		'enableClass' => 'rowHasParent'
  •   	'add' => array(
  •   		'caption' => 'Add',
  •   		'children' => array(
  •   			'new' => array(
  •   				'caption' => 'New',
  •   				'children' => $types_add,
  •   				'icon' => 'task',
  •   			'sub' => array(
  •   				'caption' => 'Sub-entry',
  •   				'url' => 'menuaction=infolog.infolog_ui.edit&action=sp&action_id=$id',
  •   				'hint' => 'Add a new sub-task, -note, -call to this entry',
  •   				'icon' => 'new',
  •   				'disableClass' => 'rowNoSubs',
  •   			'copy' => array(
  •   				'caption' => 'Copy',
  •   				'url' => 'menuaction=infolog.infolog_ui.edit&action=copy&info_id=$id',
  •   				'icon' => 'copy',
  •   	'select_all' => array(
  •   		'caption' => 'Whole query',
  •   		'checkbox' => true,
  •   		'hint' => 'Apply the action on the whole query, NOT only the shown entries',
  •   		'group' => ++$group,
  •   	'no_notifications' => array(
  •   		'caption' => 'Do not notify',
  •   		'hint' => 'Do not notify of these changes',
  •   	// modifying content of one or multiple infolog(s)
  •   	'change' => array(
  •   		'caption' => 'Change',
  •   		'icon' => 'edit',
  •   		'disableClass' => 'rowNoEdit',
  •   			'type' => array(
  •   				'caption' => 'Type',
  •   				'prefix' => 'type_',
  •   				'children' => $types,
  •   				'icon' => 'task',
  •   			'status' => array(
  •   				'caption' => 'Status',
  •   				'prefix' => 'status_',
  •   				'children' => $statis,
  •   				'icon' => 'ongoing',
  •   			'completion' => array(
  •   				'caption' => 'Completed',
  •   				'prefix' => 'completion_',
  •   				'children' => $percent,
  •   				'icon' => 'completed',
  •   			'cat' =>  nextmatch_widget::category_action(
  •   				'infolog',$group,'Change category','cat_'
  •   			'responsible' => array(
  •   				'caption' => 'Delegation',
  •   				'icon' => 'users',
  •   				'onExecute' => 'javaScript:open_popup',
  •   			'link' => array(
  •   				'caption' => 'Links',
  •   	'close' => array(
  •   		'caption' => 'Close',
  •   		'icon' => 'done',
  •   	'close_all' => array(
  •   		'caption' => 'Close all',
  •   		'icon' => 'done_all',
  •   		'hint' => 'Sets the status of this entry and its subs to done',
  •   ++$group;	// integration with other apps
  •   if ($GLOBALS['egw_info']['user']['apps']['filemanager'])
  •   	$actions['filemanager'] = array(
  •   		'icon' => 'filemanager/navbar',
  •   		'caption' => 'Filemanager',
  •   		'url' => 'menuaction=filemanager.filemanager_ui.index&path=/apps/addressbook/$id',
  •   if ($GLOBALS['egw_info']['user']['apps']['timesheet'])
  •   	$actions['timesheet'] = array(	// interactive add for a single event
  •   		'icon' => 'timesheet/navbar',
  •   		'caption' => 'Timesheet',
  •   		'url' => 'menuaction=timesheet.timesheet_ui.edit&link_app[]=infolog&link_id[]=$id',
  •   		'popup' => egw_link::get_registry('timesheet', 'add_popup'),
  •   $actions['documents'] = infolog_merge::document_action(
  •   	$this->prefs['document_dir'], ++$group, 'Insert in document', 'document_',
  •   	$this->prefs['default_document']
  •   $actions['delete'] = array(
  •   	'caption' => 'Delete',
  •   	'confirm' => 'Delete this entry',
  •   	'confirm_multiple' => 'Delete these entries',
  •   	'disableClass' => 'rowNoDelete',
  •   //echo "<p>".__METHOD__."($do_email, $tid_filter, $org_view)</p>\n"; _debug_array($actions);
  •   return $actions;
    @@ -817,34 +937,27 @@
    • @param int &$success number of succeded actions
    • @param int &$failed number of failed actions (not enought permissions)
    • @param string &$action_msg translated verb for the actions, to be used in a message like ‘%1 entries deleted’
    • @param string/array $session_name ‘index’, or array with session-data depending
    • @param array $query get_rows parameter
    • @param string &$msg on return user feedback
    • @param boolean $skip_notifications=false true to NOT notify users about changes
    • @return boolean true if all actions succeded, false otherwise
  • function action($action,$checked,$use_all,&$success,&$failed,&$action_msg,$session_name = false,&$msg, $skip_notifications = false)
  • function action($action, $checked, $use_all, &$success, &$failed, &$action_msg,
  •   array $query, &$msg, $skip_notifications = false)
    //echo “
    infolog_ui::action(’$action’,”.print_r($checked,true).’,’.(int)$use_all.",…)
    \n";
    $success = $failed = 0;
    if ($use_all)
  •   	// get the whole selection
  •   	if($session_name) {
  •   		$query = is_array($session_name) ? $session_name : egw_session::appsession($session_name,'infolog');
  •   	} else {
  •   		$query = $this->read_sessiondata();
  •   	if ($use_all)
  •   		@set_time_limit(0);                     // switch off the execution time limit, as it's for big selections to small
  •   		$query['num_rows'] = -1;        // all
  •   		$this->get_rows($query,$result,$readonlys);
  •   		$checked = array();
  •   		foreach($result as $key => $info)
  •   			if(is_numeric($key))
  •   				$checked[] = $info['info_id'];
@@ -861,17 +974,19 @@
if(!$link_id)
$action_msg = ‘linked’;
  •   			$msg = lang('You need to select an entry for linking.  ');
  •   			$msg = lang('You need to select an entry for linking.');
      			break;
      		$title = egw_link::title($app, $link_id);
      		foreach($checked as $id)
  •   			if(!$this->bo->check_access($id, EGW_ACL_EDIT)) {
      				$failed++;
      				continue;
  •   			if($add_remove == 'add') {
      				$action_msg = lang('linked to %1', $title);
      				if(egw_link::link('infolog', $id, $app, $link_id))
@@ -881,33 +996,41 @@
$failed++;
  •   			} else {
  •   			else
      				$action_msg = lang('unlinked from %1', $title);
      				$count = egw_link::unlink(0, 'infolog', $id, '', $app, $link_id);
      				$success += $count;
  •   		return ($failed == 0);
  •   		return $failed == 0;
  •   	case 'document':
      		$msg = $this->download_document($checked,$settings);
      		$failed = count($checked);
  •                            return false;
  •   		return false;
  •   	case 'view':
+// todo: implement or better move code from index to here
  •   		return false;
      // Actions that need to loop
      	if(!$entry = $this->bo->read($id))
      		continue;
  •                    switch($action)
  •   	switch($action)
      		case 'close':
      			$action_msg = lang('closed');
      			$this->close($id, '', false, $skip_notifications);
      			$success++;
      			break;
  •   		case 'delete':
      			$action_msg = lang('deleted');
      			$result = $this->delete($id, '', 'multi-action', $skip_notifications);
@@ -920,6 +1043,7 @@
$failed++;
break;
case ‘type’:
$action_msg = lang(‘changed type’);
// Dont allow to change the type, if user has no delete rights from the group-owner
@@ -937,7 +1061,8 @@
$action_msg = lang(‘changed completion to %1%’, $settings);
$entry[‘info_percent’] = $settings;
// Done entries will get changed right back if we don’t change the status too
  •   			if($entry['info_status'] == 'done') {
      				$entry['info_status'] = 'ongoing';
      			if($this->bo->write($entry, true,true,true,$skip_notifications))
@@ -963,11 +1088,14 @@
$success++;
  •   			} else {
  •   			else
      				$msg .= lang('Invalid status for entry type %1. ', lang($this->bo->enums['type'][$entry['info_type']]));
      				$failed++;
      			break;
  •   		case 'cat':
      			$cat_name = categories::id2name($settings);
      			$action_msg = lang('changed category to %1', $cat_name);
@@ -981,6 +1109,7 @@
$failed++;
break;
case ‘responsible’:
list($add_remove, $users) = explode(’_’, $settings, 2);
$action_msg = lang(‘changed responsible’) . ’ - ’ . ($add_remove == ‘add’ ? lang(‘added’) : lang(‘removed’)) . ’ ';
@@ -1003,7 +1132,7 @@
break;
    @@ -1154,36 +1283,8 @@
    if ($button)
    //Copy Infolog
  •   		if (($button == 'copy'))
  •   			unset($content['info_id']);
  •   			unset ($info_id);
  •   			unset($content['info_datemodified']);
  •   			unset($content['info_modifier']);
  •   			// Get links to be copied
  •   			$content['link_to']['to_id'] = egw_link::get_links($content['link_to']['to_app'], $content['link_to']['to_id']);
  •   			// Special mangling for files so the files get copied
  •   			foreach($content['link_to']['to_id'] as $link_id => &$link)
  •   				if ($link['app'] == egw_link::VFS_APPNAME)
  •   					$link['id'] = $link + array(
  •   						'tmp_name' => egw_link::vfs_path($link['app2'], $link['id2']).'/'.$link['id'],
  •   						'name' => $link['id'],
  •   			if($content['info_link_id'])
  •   				$info_link_id = $content['info_link_id'];
  •   				unset($content['info_link_id']);
  •   			$content['info_owner'] = !(int)$this->owner || !$this->bo->check_perms(EGW_ACL_ADD,0,$this->owner) ? $this->user : $this->owner;
  •   			$content['msg'] = lang('Infolog copied - the copy can now be edited');
  •   			$content['info_subject'] = lang('Copy of:').' '.$content['info_subject'];
  •   		if ($button == 'copy') $action = 'copy';
  •   		if ($button == 'print')
      			$content['js'] = $this->custom_print($content,!$content['info_id'])."\n".$js;	// first open the new window and then update the view
@@ -1443,7 +1544,7 @@
‘to_id’ => $info_id,
‘to_app’ => ‘infolog’,
  •   		switch ($action)
  •   	switch ($action)
      		case 'sp':
      			$links = egw_link::get_links('infolog',$parent['info_id'],'!'.egw_link::VFS_APPNAME);
@@ -1522,6 +1623,36 @@
$content[‘info_type’] = ‘note’;
  •   if ($action == 'copy')	// get's called via actions selectbox or url (action=copy&info_id=123)
  •   	unset ($info_id);
      // group owners
@@ -1966,7 +2097,7 @@
$this->called_by = $app; // for read/save_sessiondata, to have different sessions for the hooks
  •   $GLOBALS['egw']->translation->add_app('infolog');
  •   translation::add_app('infolog');
      etemplate::$hooked = true;
      $this->index(0,$app,$args[$view_id],array(
Modified: trunk/infolog/js/index.js
URL: http://www.egroupware.org/viewvc/egroupware/trunk/infolog/js/index.js?rev=34819&r1=34818&r2=34819&view=diff
— trunk/infolog/js/index.js (original)
+++ trunk/infolog/js/index.js Mon May 2 21:41:21 2011
@@ -18,6 +18,11 @@
selbox.value = “”;
+function open_popup(_action, _senders)
  • alert('Show popup: '+_action.id);
  • Hide popup and clear values
Modified: trunk/infolog/lang/egw_bg.lang
URL: http://www.egroupware.org/viewvc/egroupware/trunk/infolog/lang/egw_bg
