R35150 - /trunk/phpgwapi/js/jsapi/jsapi.js
Author: ralfbecker
New Revision: 35150
URL: http://www.egroupware.org/viewvc/egroupware?rev=35150&view=rev
nicer workaround
Modified: trunk/phpgwapi/js/jsapi/jsapi.js
URL: http://www.egroupware.org/viewvc/egroupware/trunk/phpgwapi/js/jsapi/jsapi.js?rev=35150&r1=35149&r2=35150&view=diff
— trunk/phpgwapi/js/jsapi/jsapi.js (original)
+++ trunk/phpgwapi/js/jsapi/jsapi.js Fri Jun 3 12:14:12 2011
@@ -403,30 +403,25 @@
// return the left position of the window
function egw_getWindowLeft()
function egw_getWindowTop()
// get the outerWidth of the browser window. For IE we simply return the innerWidth
@@ -464,29 +459,25 @@
function egw_getWindowOuterWidth()
// get the outerHeight of the browser window. For IE we simply return the innerHeight
function egw_getWindowOuterHeight()
// ie selectbox dropdown menu hack. as ie is not able to resize dropdown menus from selectboxes, we
Simplify data backup and recovery for your virtual environment with vRanger.
Installation’s a snap, and flexible recovery options mean your data is safe,
secure and there when you need it. Discover what all the cheering’s about.
Get your free trial download today.
http://p.sf.net/sfu/quest-dev2dev2
eGroupWare-cvs mailing list
