R36309 - in /trunk/etemplate/js: ./ test/
Author: igel457
New Revision: 36309
URL: http://svn.stylite.de/viewvc/egroupware?rev=36309&view=rev
Added et2_extension_nextmatch_dynheight.js which cares about resizing a div to the maximum possible height - this is needed because the new grid has to be explicitily sized to a given width and height
Added:
trunk/etemplate/js/et2_extension_nextmatch_dynheight.js
trunk/etemplate/js/et2_extension_nextmatch.js
trunk/etemplate/js/etemplate2.js
trunk/etemplate/js/test/test.css
trunk/etemplate/js/test/test_xml.html
Modified: trunk/etemplate/js/et2_extension_nextmatch.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/et2_extension_nextmatch.js?rev=36309&r1=36308&r2=36309&view=diff
— trunk/etemplate/js/et2_extension_nextmatch.js (original)
+++ trunk/etemplate/js/et2_extension_nextmatch.js Thu Aug 25 17:54:15 2011
@@ -20,6 +20,7 @@
et2_widget_template;
et2_widget_grid;
et2_widget_selectbox;
  • et2_extension_nextmatch_dynheight;
@@ -44,7 +45,7 @@
  • Class which implements the “nextmatch” XET-Tag
    -var et2_nextmatch = et2_DOMWidget.extend({
    +var et2_nextmatch = et2_DOMWidget.extend(et2_IResizeable, {
    attributes: {
    “template”: {
    @@ -62,6 +63,10 @@
    this.div = $j(document.createElement(“div”))
    .addClass(“et2_nextmatch”);
  •   // Create the dynheight component which dynamically scales the inner
  •   // container.
  •   this.dynheight = new et2_dynheight(null, this.div, 150);
  •   // Create the outer grid container
      this.dataviewContainer = new et2_dataview_gridContainer(this.div);
@@ -70,10 +75,14 @@
destroy: function() {
  •   // Destroy the dataview objects
      this.dataviewContainer.free();
  •   this._super.apply(this, arguments);
  •   this.dynheight.free();
  • resize: function() {
  •   this.dynheight.update();
    @@ -297,7 +306,7 @@
et2_register_widget(et2_nextmatch_header, [‘nextmatch-header’,
  • ‘nextmatch-accountfilter’, ‘nextmatch-customfilter’, ‘nextmatch-customfields’]);
  • ‘nextmatch-customfilter’, ‘nextmatch-customfields’]);
var et2_nextmatch_sortheader = et2_nextmatch_header.extend(et2_INextmatchSortable, {
@@ -347,5 +356,6 @@
-et2_register_widget(et2_nextmatch_filterheader, [‘nextmatch-filterheader’]);
+et2_register_widget(et2_nextmatch_filterheader, [‘nextmatch-filterheader’,
  • ‘nextmatch-accountfilter’]);
Added: trunk/etemplate/js/et2_extension_nextmatch_dynheight.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/et2_extension_nextmatch_dynheight.js?rev=36309&view=auto
— trunk/etemplate/js/et2_extension_nextmatch_dynheight.js (added)
+++ trunk/etemplate/js/et2_extension_nextmatch_dynheight.js Thu Aug 25 17:54:15 2011
@@ -1,0 +1,173 @@
+“use strict”
+/*egw:use
  • jquery.jquery;
  • et2_core_inheritance;
    • Object which resizes an inner node to the maximum extend of an outer node
    • (without creating a scrollbar) - it achieves that by performing some very
    • nasty and time consuming calculations.
    +var et2_dynheight = Class.extend({
    • Constructor for the dynheight object
    • @param _outerNode is the node which surrounds the _innerNode and to
    • which extend the innerNode should be expanded without creating a
    • scrollbar. Note: The outer node must be a parent of the inner node.
    • If “null” is passed, the outer node is set to “window”.
    • @param _innerNode is the node which should be scaled. Call update to
    • scale the node.
    • @param _minHeight is the minimum height the inner node should have
  • init: function(_outerNode, _innerNode, _minHeight) {
  •   this.outerNode = _outerNode ? $j(_outerNode) : $j(window);
  •   this.innerNode = $j(_innerNode);
  •   this.minHeight = _minHeight;
  •   this.bottomNodes = [];
  •   this.initialized = false;
  •   this.innerMargin = 0;
  •   this.outerMargin = 0;
    • Resizes the inner node. When this is done, the callback function is
    • called.
  • update: function(_callback, _context) {
  •   // Check whether the inner node is actually visible - if not, don't
  •   // trigger the callback function
  •   if (this.innerNode.is(":visible"))
  •   	// Initialize the height calculation
  •   	this._initialize();
  •   	// Get the outer container height
  •   	var oh = this.outerNode.height();
  •   	// Get top and height of the inner node
  •   	var it = this.innerNode.offset().top;
  •   	// Calculate the height of the "bottomNodes"
  •   	var bminTop = 0;
  •   	var bmaxBot = 0;
  •   	for (var i = 0; i < this.bottomNodes.length; i++)
  •   		// Get height, top and bottom and calculate the maximum/minimum
  •   		var bh = this.bottomNodes[i].outerHeight(true);
  •   		var bt = this.bottomNodes[i].offset().top;
  •   		var bb = bh + bt;
  •   		if (i == 0 || bminTop > bt)
  •   			bminTop = bt;
  •   		if (i == 0 || bmaxBot < bb)
  •   			bmaxBot = bb;
  •   	// Get the height of the bottom container
  •   	var bh = bmaxBot - bminTop;
  •   	// Calculate the new height of the inner container
  •   	var w = this.innerNode.width();
  •   	var h = Math.max(this.minHeight, oh - it - bh -
  •   		this.innerMargin - this.outerMargin);
  •   	this.innerNode.height(h);
  •   	// Call the callback function
  •   	if (typeof _callback != "undefined")
  •   		_callback.call(_context, _w, _h);
    • Function used internally which collects all DOM-Nodes which are located
    • below this element.
  • _collectBottomNodes: function(_node, _bottom) {
  •   // Calculate the bottom position of the inner node
  •   if (typeof _bottom == "undefined")
  •   	_bottom = this.innerNode.offset().top + this.innerNode.height();
  •   if (_node)
  •   	// Accumulate the outer margin of the parent elements
  •   	var node = $j(_node);
  •   	var ooh = node.outerHeight(true);
  •   	var oh = node.height();
  •   	this.outerMargin += (ooh - oh) / 2; // Divide by 2 as the value contains margin-top and -bottom
  •   	// Iterate over the children of the given node and do the same
  •   	// recursively to the parent nodes until the _outerNode or body is
  •   	// reached.
  •   	var self = this;
  •   	$j(_node).children().each(function() {
  •   		var $this = $j(this);
  •   		var top = $this.offset().top;
  •   		if (this != self.innerNode[0] && top > _bottom)
  •   			self.bottomNodes.push($this);
  •   	if (_node != this.outerNode[0] && _node != $j("body")[0])
  •   		this._collectBottomNodes(_node.parentNode, _bottom);
    • Used internally to calculate some information which will not change over
    • the time.
  • _initialize: function() {
  •   if (!this.initialized)
  •   	// Collect all bottomNodes and calculates the outer margin
  •   	this._collectBottomNodes(this.innerNode[0].parentNode);
  •   	// Calculate the inner margin
  •   	var ioh = this.innerNode.outerHeight(true);
  •   	var ih = this.innerNode.height();
  •   	this.innerMargin = ioh - ih;
  •   	// Calculate the outer margin
  •   	var node = this.outerNode;
  •   	if (node[0] == window)
  •   		node = $j("body");
  •   	this.initialized = true;
Modified: trunk/etemplate/js/etemplate2.js
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/etemplate2.js?rev=36309&r1=36308&r2=36309&view=diff
— trunk/etemplate/js/etemplate2.js (original)
+++ trunk/etemplate/js/etemplate2.js Thu Aug 25 17:54:15 2011
@@ -34,6 +34,7 @@
// Requirements for the etemplate2 object
et2_core_xml;
et2_core_arrayMgr;
  • et2_core_interfaces;
@@ -57,8 +58,26 @@
// Preset the object variable
this.widgetContainer = null;
  • // Connect to the window resize event
  • $j(window).resize(this, function(e) {e.data.resize()});
  • // Associative array with the event listeners
    this.listeners = {};
    • Calls the resize event of all widgets
    +etemplate2.prototype.resize = function()
  • if (this.widgetContainer)
  •   // Call the "resize" event of all functions which implement the
  •   // "IResizeable" interface
  •   this.widgetContainer.iterateOver(function(_widget) {
  •   	_widget.resize();
  •   }, this, et2_IResizeable);
@@ -129,8 +148,12 @@
et2_loadXMLFromURL(_url, function(_xmldoc) {
// Read the XML structure
this.widgetContainer.loadFromXML(_xmldoc);
// Inform the widget tree that it has been successfully loaded.
this.widgetContainer.loadingFinished();
  •   // Trigger the "resize" event
  •   this.resize();
    }, this);
    // Clear any existing instance
Modified: trunk/etemplate/js/test/test.css
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/test/test.css?rev=36309&r1=36308&r2=36309&view=diff
— trunk/etemplate/js/test/test.css (original)
+++ trunk/etemplate/js/test/test.css Thu Aug 25 17:54:15 2011
@@ -9,6 +9,7 @@
body, table, td {
font-family: Lucida Grande, sans-serif;
font-size: 10pt;
+/* overflow: hidden;*/
#linklist a {
Modified: trunk/etemplate/js/test/test_xml.html
URL: http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/test/test_xml.html?rev=36309&r1=36308&r2=36309&view=diff
— trunk/etemplate/js/test/test_xml.html (original)
+++ trunk/etemplate/js/test/test_xml.html Thu Aug 25 17:54:15 2011
@@ -32,6 +32,7 @@
	<script src="../et2_extension_nextmatch.js"></script>
  •   <script src="../et2_extension_nextmatch_dynheight.js"></script>
      <script src="../et2_dataview_view_gridcontainer.js"></script>
      <script src="../etemplate2.js"></script>
@@ -79,6 +80,7 @@
ETemplate2 container:
  •   <div style="color: silver;">[Just here to test the dynheight component...]</div>
      <script>
      	var et2 = new etemplate2(document.getElementById("container"), "");
EMC VNX: the world’s simplest storage, starting under $10K
The only unified storage solution that offers unified management
Up to 160% more powerful than alternatives and 25% more efficient.
Guaranteed. http://p.sf.net/sfu/emc-vnx-dev2dev
eGroupWare-cvs mailing list
