Do you mind to send your config files for that I can compare with my?
.htaccess:
php_value memory_limit 128M
php_value max_execution_time 60
php_flag register_globals Off
php_flag magic_quotes_gpc Off
php_flag magic_quotes_runtime Off # settings for the file upload, you might increase them further
php_value upload_max_filesize 16M # session handling: now the check for expired sessions is done on
every 10th session creation
php_flag session.use_trans_sid Off
php_value session.gc_probability 1
php_value session.gc_divisor 10 # multibyte extension: needed for utf-8
php_value mbstring.func_overload 7
PHP info:
Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference On On
allow_url_fopen On On
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 6135 6135
expose_php On On
extension_dir /usr/lib/php5/20060613+lfs /usr/lib/php5/20060613+lfs
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
log_errors Off Off
log_errors_max_len 1024 1024
magic_quotes_gpc Off On
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.force_extra_parameters no value no value
max_execution_time 60 30
max_input_nesting_level 64 64
max_input_time 60 60
memory_limit 128M 128M
open_basedir no value no value
output_buffering no value no value
output_handler no value no value
post_max_size 8M 8M
precision 12 12
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv On On
register_globals Off Off
register_long_arrays On On
report_memleaks On On
report_zend_debug On On
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
suhosin.log.phpscript 0 0
suhosin.log.phpscript.is_safe Off Off
suhosin.log.phpscript.name no value no value
suhosin.log.sapi no value no value
suhosin.log.script no value no value
suhosin.log.script.name no value no value
suhosin.log.syslog no value no value
suhosin.log.syslog.facility no value no value
suhosin.log.syslog.priority no value no value
suhosin.log.use-x-forwarded-for Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 16M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.ze1_compatibility_mode Off Off
bcmath
BCMath support enabled
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bz2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.5, 10-Dec-2007
calendar
Calendar support enabled
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information libcurl/7.18.2 OpenSSL/0.9.8g zlib/1.2.3.3 libidn/
1.14 libssh2/1.0
date
date/time support enabled
"Olson" Timezone Database Version 0.system
Timezone Database internal
Default timezone System/Localtime
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone no value no value
dba
DBA support enabled
Supported handlers cdb cdb_make db4 inifile flatfile
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.3
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
EXIF Version 1.4 $Id: exif.c,v 1.173.2.5.2.27 2008/12/31 11:17:37
sebastian Exp $
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
filter
Input Validation and Filtering enabled
Revision $Revision: 1.52.2.45 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
gd
GD Support enabled
GD Version 2.0 or higher
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.3.9
T1Lib Support enabled
GIF Read Support enabled
GIF Create Support enabled
JPG Support enabled
PNG Support enabled
WBMP Support enabled
gettext
GetText Support enabled
gmp
gmp support enabled
GMP version 4.2.4
gnupg
gnupg support enabled
GPGme Version 1.1.8
Extension Version 1.3.1
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha256 sha384 sha512 ripemd128
ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3
tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru gost adler32 crc32
crc32b haval128,3 haval160,3 haval192,3 haval224,3 haval256,3
haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5
haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.9
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
json
json support enabled
json version 1.2.1
libxml
libXML support active
libXML Version 2.7.3
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) version 4.4.4
Multibyte regex (oniguruma) backtrack check On
mbstring extension makes use of “streamable kanji code filter and
converter”, which is distributed under the GNU Lesser General Public
License version 2.1.
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input pass pass
mbstring.http_output pass pass
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mime_magic
mime_magic support invalid magic file, disabled
mime_magic.debug Off Off
mime_magic.magicfile /usr/share/file/magic.mime /usr/share/file/
magic.mime
mysql
MySQL Support enabled
Active Persistent Links 3
Active Links 4
Client API version 5.0.51a
MYSQL_MODULE_TYPE external
MYSQL_SOCKET /var/run/mysqld/mysqld.sock
MYSQL_INCLUDE -I/usr/include/mysql
MYSQL_LIBS -L/usr/lib -lmysqlclient_r
mysql.allow_persistent On On
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket no value no value
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
mysqli
MysqlI Support enabled
Client API library version 5.0.51a
Client API header version 5.0.81
MYSQLI_SOCKET /var/run/mysqld/mysqld.sock
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.reconnect Off Off
openssl
OpenSSL support enabled
OpenSSL Version OpenSSL 0.9.8g 19 Oct 2007
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 7.8 2008-09-05
pcre.backtrack_limit 100000 100000
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql
pdo_mysql
PDO Driver for MySQL, client library version 5.0.51a
posix
Revision $Revision: 1.70.2.3.2.22 $
Reflection
Reflection enabled
Version $Id: php_reflection.c,v 1.164.2.33.2.55 2008/12/31 11:17:42
sebastian Exp $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 On On
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 10 100
session.gc_maxlifetime 14400 1440
session.gc_probability 1 0
session.hash_bits_per_character 4 4
session.hash_function 0 0
session.name sessionid PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /var/lib/php5 /var/lib/php5
session.serialize_handler php php
session.use_cookies Off On
session.use_only_cookies Off Off
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Revision: 1.151.2.22.2.46 $
Schema support enabled
soap
Soap Client enabled
Soap Server enabled
soap.wsdl_cache 1 1
soap.wsdl_cache_dir /tmp /tmp
soap.wsdl_cache_enabled 1 1
soap.wsdl_cache_limit 5 5
soap.wsdl_cache_ttl 86400 86400
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator,
SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject,
BadFunctionCallException, BadMethodCallException, CachingIterator,
DirectoryIterator, DomainException, EmptyIterator, FilterIterator,
InfiniteIterator, InvalidArgumentException, IteratorIterator,
LengthException, LimitIterator, LogicException, NoRewindIterator,
OutOfBoundsException, OutOfRangeException, OverflowException,
ParentIterator, RangeException, RecursiveArrayIterator,
RecursiveCachingIterator, RecursiveDirectoryIterator,
RecursiveFilterIterator, RecursiveIteratorIterator,
RecursiveRegexIterator, RegexIterator, RuntimeException,
SimpleXMLIterator, SplFileInfo, SplFileObject, SplObjectStorage,
SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=,fieldset=
user_agent no value no value
sysvmsg
sysvmsg support enabled
Revision $Revision: 1.20.2.3.2.8 $
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.7.3
xmlreader
XMLReader enabled
xmlrpc
core library version xmlrpc-epi v. 0.51
php extension version 0.51
author Dan Libby
homepage http://xmlrpc-epi.sourceforge.net
open sourced by Epinions.com
xmlwriter
XMLWriter enabled
zip
Zip enabled
Extension Version $Id: php_zip.c,v 1.1.2.49 2009/02/05 19:53:22
pajoye Exp $
Zip version 1.8.11
Libzip version 0.9.0
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.1.1
Linked Version 1.2.3.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Nathan Gray
nathan at goarctic dot com
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, &
iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
Perp-developers mailing list
Perp-developers@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/perp-developers
