SiteMGR question]
I made a site with SiteMGR, called www.something.org
I can reach it with URL http://www.something.org
But, if I try to reach the same site with URL http://something.org, I
got this error message:
THERE IS NO WEBSITE CONFIGURED FOR URL http://something.org/
(soMething). NOTIFY THE ADMINISTRATOR.*
How can I setup the site to accept both URL formula?
Regards, István
Pongracz Istvan wrote:
URL http://www.something.org to be the same URL as http://something.org,
you need to define them as same host. You kan solve it with make
something.org as CNAME to www.something.org in your DNS. This may not be
the best solution, but it works. There may be some other better solution.
Regards, István
Regards
Jon Ingason
Thank you, I will try it.
Regards,
István
http://something.org, you need to define them as same host. You kan
solve it with make something.org as CNAME to www.something.org in your
DNS. This may not be the best solution, but it works. There may be
Regards, István
Hi Jon,
The trick was that:
I create a new website (using Define websites).
To URL I set up http://something.org
I added th redirection module to the website, which is point to
http://www.something.org.
That’s all.
Regards, István
Regards,
István
I got this error message:
your DNS. This may not be the best solution, but it works. There may
Regards, István
