I found a little display glitch in the email view (also preview).
When a message comes with plain text - an email-address is displayed
quite strange: Before and after the address there are additional
blanks and when pointing the the address (hover) the underline goes
before and after the address.
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing. http://p.sf.net/sfu/oracle-sfdevnl
In a way sure, not via UI, but by coding - yes.
But it is (can be) a quite complex issue. Not an easy one to tell you where to go and what to do (, depending on what you want to do exactly.)
What I want, very simple:
That links (http and email) are underlined (not only on hoover) and
that the colors of links for http and email links are the same.
Email links don’t have additional blanks before and after the
link-text.
you may have a look in the meantime at class.uidisplay.inc.php
function makeComposeLink and parseHREF
In makeComposeLink (trunk, line 213) the color of the link is explizitly defined, you may remove that, and the spaces before and after the email are added (Remove them too).
Please report any unwanted sideeffects, that may occur.
removing spaces worked well - no “unwanted sideeffect” noticed. In my
opinion it makes really no sense to have these spaces before and after
the address. Changing color works as well.
I would like to have the hint now where to change the color of the
http-link - seems to be not in this file.
Thanks.
Tin
Wednesday, January 19, 2011, 1:42:01 PM, you wrote:
I take that as feature request.
link-text.
