Hi all
I’m facing a strange problem with projectmanager.
Basically I’m not able to add new projects anymore. When I press the
"Add"
button at the bottom of the project list view I get simply the same
page
reloaded (the project list one) but no new projects are added.
I cannot say exactly when this strange behaviour started, but I
suspect that
it may be after upgrading to 1.2-102.
I’ve already made a test on a different egw installation, and I can
say that
it is definitely not a 1.2-102 bug but something weird that happened
to my
main installation probably during upgrade.
I also tried to uninstall project manager and then reinstall it. Doing
this
I loose all my project data, but the application works as expected. If
I
restore data from a a previously made backup things start to go wrong
again.
So probably the problem is on some mysql table (maybe the project
manager
hooks ones)
Can anyone give me some suggestion/help to solve my problem?
Is there something I can check/modify on mysql tables?
I really would NOT make a new installation from scratch and re-enter
all
data …
Thanks in advance and regards
