Ok, checks should now report jpgraph directory correct, even if
open_basedir forbids access to parent of EGroupware directory.
Also allowing now jpgraph.php directly in jpgraph directory, like Debian
libphp-jpgraph package (which is still a very old version not supporting
all features), or a src sub-directory.
Hi Hans-Jürgen,
Hi!
Libphp-jpgraph is too old! You have to unpack. Jpgraph in the given directory. If it get not detected, problem could be open_basedir, permission or a wrong location.
Problem was that I installed the src/ directory into /jpgraph, so the
VERSION file was missing.
My fault, but unusual to pack jpgraph into a tgz without initial
directory.
That changed with recent versions of jpgraph, before the tgz always
contained a jpgraph-2.xx directory …
I’m thinking about changing the layout of our jpgraph packages to be
compatible with libphp-jpgraph (content of src dir plus VERSIONS file
direct in /usr/share/jpgraph). We can easily detect if it contains the
src dir or not, and work with both.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
