Sir
I am using using egroupware 1.8 ce since long and always submit stats with
the id.
But when i tried to get the id/pwd of group admin app, browser behaved badly
What do you mean with browser behaves badly?
and could not load the page when i refreshed i could not find any ID / PWD.
A correct submission opens an other tab/window showing
http://community.egroupware.org/usage-statistic
Plus at least following text above:
Thank you for contributing to EGroupware usage statistic.
Your submission is number 45366.
I’m trying to understand what you are seeing.
Please mail me your submission-ID to rb@stylite.de, so I can have a
look, if your submission was received.
As far as I can tell the system is working and issued more then 100
credentials to community members in the last days.
Now how can i get the same, pl help.
One more question, i want to migrate this server to another server, should i
now install 14.1 there and upload old db will it be possible?
Yes, that’s how the update works.
You can install a new/empty 14.1, copy your old files directory
(/var/lib/egroupware/default/files by default, or what every you choose
in Setup), restore database dump and upgrade it in Setup.
