Let me know if replacing the file fixes the problem for you.
Hello,
I’m running 14.1 on CentOS_6 with postgresql 9.2. When I open Projects
I’m getting the following error:
Database error
Invalid SQL: SELECT SUM(pe_completion * (CASE WHEN pe_share IS NULL
AND pe_planned_time IS NULL AND pe_replanned_time IS NULL THEN 240
WHEN pe_share IS NULL AND pe_planned_time IS NULL THEN
pe_replanned_time WHEN pe_share IS NULL THEN pe_planned_time ELSE
pe_share END)) AS pe_sum_completion_shares,SUM(CASE WHEN pe_completion
IS NULL THEN NULL ELSE (CASE WHEN pe_share IS NULL AND pe_planned_time
IS NULL AND pe_replanned_time IS NULL THEN 240 WHEN pe_share IS NULL
AND pe_planned_time IS NULL THEN pe_replanned_time WHEN pe_share IS
NULL THEN pe_planned_time ELSE pe_share END) END) AS
pe_total_shares,SUM(pe_used_time) AS pe_used_time,SUM(pe_planned_time)
AS pe_planned_time,SUM(pe_replanned_time) AS
pe_replanned_time,SUM(pe_used_budget) AS
pe_used_budget,SUM(pe_planned_budget) AS
pe_planned_budget,MIN(pe_real_start) AS
pe_real_start,MIN(pe_planned_start) AS
pe_planned_start,MAX(pe_real_end) AS pe_real_end,MAX(pe_planned_end)
AS pe_planned_end,CASE WHEN link_app1=‘projectmanager’ AND
link_id1=CAST(pm_id AS varchar) THEN link_app2 ELSE link_app1 END AS
pe_app,CASE WHEN link_app1=‘projectmanager’ AND link_id1=CAST(pm_id AS
varchar) THEN link_id2 ELSE link_id1 END AS pe_app_id,link_remark AS
pe_remark FROM egw_pm_elements ,egw_links WHERE pe_id=link_id AND
(pm_id IS NULL AND pe_status != ‘ignore’)
ERROR: column “egw_links.link_app1” must appear in the GROUP BY
clause or be used in an aggregate function
LINE 1: …d,MAX(pe_planned_end) AS pe_planned_end,CASE WHEN link_app1=…
^ (-1)
The page will then open, but if I try to add a new project, nothing
happens except a red blinking icon which shows this error:
TypeError: app.projectmanager is undefined
log_on_client@http://10.10.10.93/egroupware/phpgwapi/inc/min/?b=egroupware&f=phpgwapi/js/jquery/jquery.js,phpgwapi/js/jquery/jquery-ui.js,phpgwapi/js/jsapi/jsapi.js,phpgwapi/js/egw_json.js,phpgwapi/js/jsapi/egw_core.js,phpgwapi/js/jsapi/egw_debug.js,phpgwapi/js/jsapi/egw_preferences.js,phpgwapi/js/jsapi/egw_utils.js,phpgwapi/js/jsapi
/egw_rea
dy.js,phpgwapi/js/jsapi/egw_files.js,phpgwapi/js/jsapi/egw_lang.js,phpgwapi/js/jsapi/egw_links.js,phpgwapi/js/jsapi/egw_open.js,phpgwapi/js/jsapi/egw_user.js,phpgwapi/js/jsapi/egw_config.js,phpgwapi/js/jsapi/egw_images.js,phpgwapi/js/jsapi/egw_jsonq.js,phpgwapi/js/jsapi/egw_json.js,phpgwapi/js/jsapi/egw_store.js,phpgwapi/js/jsapi/egw_tooltip.js,phpgwapi/js/jsapi/egw_css.js,phpgwapi/js/jquery/jquery-ui-timepicker-addon.js,phpgwapi/js/jsapi/egw_calendar.js,phpgwapi/js/jsapi/egw_data.js,phpgwapi/js/jsapi/egw_tail.js,phpgwapi/js/jsapi/egw_inheritance.js,phpgwapi/js/jsapi/egw_message.js,phpgwapi/js/jsapi/app_base.js,phpgwapi/js/dhtmlxtree/codebase/dhtmlxcommon.js,phpgwapi/js/dhtmlxtree/sources/dhtmlxtree.js,phpgwapi/js/dhtmlxtree/sources/ext/dhtmlxtree_json.js,phpgwapi/js/egw_action/egw_action_common.js,phpgwapi/js/egw_action/egw_action.js,phpgwapi/js/egw_action/egw_keymanager.js,phpgwapi/js/egw_action/egw_menu.js,phpgwapi/js/egw_action/egw_action_popup.js,phpgwapi/js/egw_action/e
gw_actio
n_dragdrop.js,phpgwapi/js/egw_action/egw_dragdrop_dhtmlx_tree.js,phpgwapi/js/dhtmlxMenu/sources/dhtmlxmenu.js,phpgwapi/js/dhtmlxMenu/sources/ext/dhtmlxmenu_ext.js,phpgwapi/js/egw_action/egw_menu_dhtmlx.js&1411480878:2144:6
@http://10.10.10.93/egroupware/phpgwapi/inc/min/?b=egroupware&f=phpgwapi/js/jquery/jquery.js,phpgwapi/js/jquery/jquery-ui.js,phpgwapi/js/jsapi/jsapi.js,phpgwapi/js/egw_json.js,phpgwapi/js/jsapi/egw_core.js,phpgwapi/js/jsapi/egw_debug.js,phpgwapi/js/jsapi/egw_preferences.js,phpgwapi/js/jsapi/egw_utils.js,phpgwapi/js/jsapi/egw_ready.js,phpgwapi/js/jsapi/egw_files.js,phpgwapi/js/jsapi
/egw_lan
g.js,phpgwapi/js/jsapi/egw_links.js,phpgwapi/js/jsapi/egw_open.js,phpgwapi/js/jsapi/egw_user.js,phpgwapi/js/jsapi/egw_config.js,phpgwapi/js/jsapi/egw_images.js,phpgwapi/js/jsapi/egw_jsonq.js,phpgwapi/js/jsapi/egw_json.js,phpgwapi/js/jsapi/egw_store.js,phpgwapi/js/jsapi/egw_tooltip.js,phpgwapi/js/jsapi/egw_css.js,phpgwapi/js/jquery/jquery-ui-timepicker-addon.js,phpgwapi/js/jsapi/egw_calendar.js,phpgwapi/js/jsapi/egw_data.js,phpgwapi/js/jsapi/egw_tail.js,phpgwapi/js/jsapi/egw_inheritance.js,phpgwapi/js/jsapi/egw_message.js,phpgwapi/js/jsapi/app_base.js,phpgwapi/js/dhtmlxtree/codebase/dhtmlxcommon.js,phpgwapi/js/dhtmlxtree/sources/dhtmlxtree.js,phpgwapi/js/dhtmlxtree/sources/ext/dhtmlxtree_json.js,phpgwapi/js/egw_action/egw_action_common.js,phpgwapi/js/egw_action/egw_action.js,phpgwapi/js/egw_action/egw_keymanager.js,phpgwapi/js/egw_action/egw_menu.js,phpgwapi/js/egw_action/egw_action_popup.js,phpgwapi/js/egw_action/egw_action_dragdrop.js,phpgwapi/js/egw_action/egw_dragdrop_dhtm
lx_tree.
js,phpgwapi/js/dhtmlxMenu/sources/dhtmlxmenu.js,phpgwapi/js/dhtmlxMenu/sources/ext/dhtmlxmenu_ext.js,phpgwapi/js/egw_action/egw_menu_dhtmlx.js&1411480878:2184:39
jQuery.event.dispatch@http://10.10.10.93/egroupware/phpgwapi/inc/min/?b=egroupware&f=phpgwapi/js/jquery/jquery.js,phpgwapi/js/jquery/jquery-ui.js,phpgwapi/js/jsapi/jsapi.js,phpgwapi/js/egw_json.js,phpgwapi/js/jsapi/egw_core.js,phpgwapi/js/jsapi/egw_debug.js,phpgwapi/js/jsapi/egw_preferences.js,phpgwapi/js/jsapi/egw_utils.js,phpgwapi/js/jsapi/egw_read
y.js,php
gwapi/js/jsapi/egw_files.js,phpgwapi/js/jsapi/egw_lang.js,phpgwapi/js/jsapi/egw_links.js,phpgwapi/js/jsapi/egw_open.js,phpgwapi/js/jsapi/egw_user.js,phpgwapi/js/jsapi/egw_config.js,phpgwapi/js/jsapi/egw_images.js,phpgwapi/js/jsapi/egw_jsonq.js,phpgwapi/js/jsapi/egw_json.js,phpgwapi/js/jsapi/egw_store.js,phpgwapi/js/jsapi/egw_tooltip.js,phpgwapi/js/jsapi/egw_css.js,phpgwapi/js/jquery/jquery-ui-timepicker-addon.js,phpgwapi/js/jsapi/egw_calendar.js,phpgwapi/js/jsapi/egw_data.js,phpgwapi/js/jsapi/egw_tail.js,phpgwapi/js/jsapi/egw_inheritance.js,phpgwapi/js/jsapi/egw_message.js,phpgwapi/js/jsapi/app_base.js,phpgwapi/js/dhtmlxtree/codebase/dhtmlxcommon.js,phpgwapi/js/dhtmlxtree/sources/dhtmlxtree.js,phpgwapi/js/dhtmlxtree/sources/ext/dhtmlxtree_json.js,phpgwapi/js/egw_action/egw_action_common.js,phpgwapi/js/egw_action/egw_action.js,phpgwapi/js/egw_action/egw_keymanager.js,phpgwapi/js/egw_action/egw_menu.js,phpgwapi/js/egw_action/egw_action_popup.js,phpgwapi/js/egw_action/egw_action
_dragdro
p.js,phpgwapi/js/egw_action/egw_dragdrop_dhtmlx_tree.js,phpgwapi/js/dhtmlxMenu/sources/dhtmlxmenu.js,phpgwapi/js/dhtmlxMenu/sources/ext/dhtmlxmenu_ext.js,phpgwapi/js/egw_action/egw_menu_dhtmlx.js&1411480878:309:372
jQuery.event.add/elemData.handle@http://10.10.10.93/egroupware/phpgwapi/inc/min/?b=egroupware&f=phpgwapi/js/jquery/jquery.js,phpgwapi/js/jquery/jquery-ui.js,phpgwapi/js/jsapi/jsapi.js,phpgwapi/js/egw_json.js,phpgwapi/js/jsapi/egw_core.js,phpgwapi/js/jsapi/egw_debug.js,phpgwapi/js/jsapi/egw_preferences.js,phpgwapi/js/jsapi/egw_utils.js,phpg
wapi/js/
jsapi/egw_ready.js,phpgwapi/js/jsapi/egw_files.js,phpgwapi/js/jsapi/egw_lang.js,phpgwapi/js/jsapi/egw_links.js,phpgwapi/js/jsapi/egw_open.js,phpgwapi/js/jsapi/egw_user.js,phpgwapi/js/jsapi/egw_config.js,phpgwapi/js/jsapi/egw_images.js,phpgwapi/js/jsapi/egw_jsonq.js,phpgwapi/js/jsapi/egw_json.js,phpgwapi/js/jsapi/egw_store.js,phpgwapi/js/jsapi/egw_tooltip.js,phpgwapi/js/jsapi/egw_css.js,phpgwapi/js/jquery/jquery-ui-timepicker-addon.js,phpgwapi/js/jsapi/egw_calendar.js,phpgwapi/js/jsapi/egw_data.js,phpgwapi/js/jsapi/egw_tail.js,phpgwapi/js/jsapi/egw_inheritance.js,phpgwapi/js/jsapi/egw_message.js,phpgwapi/js/jsapi/app_base.js,phpgwapi/js/dhtmlxtree/codebase/dhtmlxcommon.js,phpgwapi/js/dhtmlxtree/sources/dhtmlxtree.js,phpgwapi/js/dhtmlxtree/sources/ext/dhtmlxtree_json.js,phpgwapi/js/egw_action/egw_action_common.js,phpgwapi/js/egw_action/egw_action.js,phpgwapi/js/egw_action/egw_keymanager.js,phpgwapi/js/egw_action/egw_menu.js,phpgwapi/js/egw_action/egw_action_popup.js,phpgwapi/js
/egw_act
ion/egw_action_dragdrop.js,phpgwapi/js/egw_action/egw_dragdrop_dhtmlx_tree.js,phpgwapi/js/dhtmlxMenu/sources/dhtmlxmenu.js,phpgwapi/js/dhtmlxMenu/sources/ext/dhtmlxmenu_ext.js,phpgwapi/js/egw_action/egw_menu_dhtmlx.js&1411480878:282:114
myEMAILsignature Thomas Plancon
CAD/IT Manager
B K A Architects, Inc.
142 Crescent Street
Brockton, MA 02302
tel: 508 . 583 . 5603 ext 313
fax: 508 . 584 . 2914
www.bkaarchitects.com http://www.bkaarchs.com/
Slashdot TV. Videos for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
