Ralf, Nathan, All,
Last two issues that are causing me grief tonight are:
(1) How do I hide the side menu when using the pixelegg template? I know Ralf
has said idots will go away (which I think is a huge mistake), but when I try
and use pixelegg, egroupware is unusable because a Full-25% of the screen is
wasted on the menu. Specifically 14.3 pixelegg is complete unusable:
http://www.3111skyline.com/dl/bugs/egw/address_pixelegg.jpg
compared to the clean idots display:
http://www.3111skyline.com/dl/bugs/egw/address_idots.jpg
In 14.3 with pixelegg nothing is readable! How am I supposed to tell whose
address is whose when I cannot even read the name in addressbook?
With pixelegg in can only see (but not read who) a total of 4 addresses
per-page. What gives?
With idots I can clearly read 10 full addresses with the full-names, addresses,
photos, phone numbers, e-mails, and the essential custom fields perfectly.
How do I make 14.3 do that?
If I can’t make 14 work on a basic level to cleanly display the basic
information from my database, I’ll have to scrap 14 again and reinstall 1.8.
What good are all the improvements if you can’t read your data anymore?
(2) How do I turn off that 1-inch thick tool tip that keeps popping up all
the time?
Is there a global setting for it? That would help make the interface less
distracting. Every time my mouse moves a little bit, I get this giant banner of
tooltips flashing across the screen. In idots, they flash across the screen
wherever the mouse is (all the way across the screen). In pixelegg the flash at
the top of the current window, but make it look like a slot-machine. I just want
a way to turn the all OFF. What’s the trick?
David C. Rankin, J.D.,P.E.
