Hi Hans-Jürgen,
Hi Ralf and Developers!
After the update to 1.8.004.20130816, I have 2 problems:
- In installations with the user accounts in MySQL, I cannot login any
more. (LDAP Installation still works). is there anything I could do
to help?
Hmm, tried with my just updated svn checkout and I can login with
accounts in SQL.
Can you be a bit more specific: do you get a blank page (Apache
error-log) or a message in red about credentials box on login page?
- In the egroupware-gallery packages, the files main.php, init,inc and
index.php are missing in the main directory. Can you please re-add
them?
Hmm, we use gallery’s svn as an external, so I cant change is there.
Need to look into it …
Thanks for maintaining the update packages.
Hans-Jürgen
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
