Hello,
I want convert the app Timesheet for other specifications and now I have got
the problem that he does not accept the default templates!
Can it be that the links for the defaults are controlled of an other place
than directly through the app?
How did you convert? Did you change the template used in the code, or
change the timesheet eTemplate?
If you only changed the code, you should be able to revert your
changes. If you changed the timesheet etemplate, delete your version
(you did change the version number, right?) from the etemplate list.
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
