which EGroupware version are you using?
In 14.1 SyncML is no longer packaged by default (while entry point
rpc.php is still there!).
To install it manually either check it our via SVN or download it’s tgz
from our svn server:
http://svn.stylite.de/viewvc/egroupware/trunk/syncml/
(See “Download GNU tarball” link below).
Hi
I changed my Linux distribution and wanted to set up eGroupware completely
from scratch. I was able to finish the installation an can perfectly log in
on http://server_ip/egroupware from my webbrowser. Moreover, using Icedove I
was also able to set up a remote address book using a Sogo-connector.
However, the final step would be to reload the server with one of my clients
data. I wanted to use my smartphone and Synthesis, which worked perfectly in
the past. I used as server path
http://server_ip/egroupware/rpc.php
And for contacts and calendar the following: ./contacts and ./events
But I always get “Acces Denied”. I retried this several times always typing
in my password. So this should be correct. What could be the problem?
cheers
nutshell4
