That has nothing to do with adding via command line or GUI.
Accounts in eGroupware have to be in the Accounts addressbook. Noone can
(is allowed) to move them somewhere else (because they would no longer
be accounts!).
Currently Accounts are either readable by everyone, only by admins or by
noone (in Addressbook). There’s currently only an option to display only
the primary group to regular users, but that option is not implemented
for addressbook, only for the account selection. Thought you can use a
forced addressbook pref to switch the account display in addressbook
completely off.
Limiting the addressbook to only display the primary group for
non-admins, is not a big deal, it’s just not implemented currently.
webtent schrieb:
I also noticed that after I added the user with the command line script and
then go into the GUI and to the addressbook and select to move my own entry
into the private addressbook, its says…
0 contact(s) moved, 1 failed because of insufficent rights !!!
The user is also able to view all other entries including the admin. What we
want to accomplish is for new user accounts can only see themselves and
their own entries in the addressbook. However, we want the admin user to see
all. Is there a way to do this?
I tried to create a group and put that user in only that group and set the
primary group for the user to that group. I then made sure that the group
had nothing checked under ‘Grant access’ while logged in as admin in the
addressbook, but the user can still see the admin and everyone else in the
Default group.
ralfbecker wrote:
Creating the account with admin-cli.php works for me: I create the
account with the command line you gave and then log in with my admin
account to see it’s there. Loging out again, I can also log in with the
new account.
Only problem I can imagine is caching: If you have a running session and
already searched/listed accounts, that query get’s cached. So the new
account would not show up until you log out and in again.
Apart from that, I would recommend to try again on a fresh install,
maybe your trials with your own script got the database in an
inconsistent state.
webtent schrieb:
I got all the kinks worked out to make entries in the db directly using a
custom script, but pulling my hair out trying to figure out why the user
account does not show up in the GUI afterward. So, I decided to try the
admin-cli.php script on the command line to spot differences, but having
the
exact same problem…I run this command…
esmtp# php admin-cli.php --edit-user
admin,mypass,test,first-name,last-name,password,myuser@example.com
Account test created with id #32
But the account does not show up in the GUI, what I’m a doing wrong?
Seems
if I play around enough searching by alphabet, logging in and out, I can
get
these newly created users to show up.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 7815917
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
This SF.Net email is sponsored by the Moblin Your Move Developer’s
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
[open style of IT]
www.stylite.de
www.egroupware.org
