I am using activesync for my emails, but it doesn’t sync all folders and not all the mail in the other folders on my iPhone
IOS v10.0.2 even I have set sync to unlimited on the iPhone.
I found following entry in z-push.log which would indicate there is a timeout issue on the server.
INFO] [horst] StatusException: SyncCollections->CheckForChanges(): Timeout forced after 31s from 600s due to other process - code: 3 - file: /opt/local/share/egroupware/activesync/vendor/z-push/z-push/src/lib/core/synccollections.php:586
Are there any other settings to consider?
Thanks and Regards,
Horst
