I want to make 2 echo but not with a common scrollbar !!
I want 2 scrollbars.
Do you know what is the class that deals with echo ?
I just know the calendar view is called in the fonction &planner($home=false) in class.calendar_uiviews ;
and the function do_header($content_=NULL) in class.calendar_ui
Thanks
