Hi
I have huge problems getting the Addressbook to work with LDAP. Running Centos 6, the OpenLDAP configuration needs to be done with converting to LDIF files, instead of using the old style slapd.conf.
I have copied the ACLs from the Addressbook readme and included this file. When I have converted the config to ldif files using slaptest there are no issues.
But I have problems as admin or user to Create contacts in either Personal or Group Contacts. In Egroupware I have the permissions, but LDAP still say that I have insufficient permissions (error code 50).
I have read somewhere that the ACLs provided does not work with the new style of configuring OpenLDAP. Can anyone confirm this?
Any help would be much appreciated.
Best Regards
Michael
