Hi Christophe,
i’m not talking of group-adressbooks. The contact-type is e.g.
n=contacts, you can create and check this in Adressbook->admin->customfields
The contact-types are mentioned at the top. If there is no type shown,
this means that the default-contact-type was deleted somehow. On the
Adressbook-list-view should be an selectbox for Type (as soon as there
are more than one type)
Birgit
Thanks for responding,
Could you please explain what you mean with “addressbook-types”. In my
case, all users have access to several addressbooks. As I create a new
user account, I can only give him existing groups… so the default is
still existing.
One other thing very important is that other user accounts still work
perfectly. If I give exactly the same rights of an existing user to a
new one, he doesn’t see any contact…
Christophe
Le jeudi 24 février 2011 à 19:12 +0100, Birgit Becker Stylite GmbH a
écrit :
Please check, if you have probably different adressbook-types in use or
the default type contact s maybe removed
Birgit
Hello Developpers,
I encountered a problem with the addressbook a few days ago.
It’s the first time I create a new group and new users since I migrated from
version1.6 to 1.8.
When I give a new user access to an existing group ( which contains tons of
contacts), he can’t see anything in the addressbook anymore… even if he
creates new ones.
Furthermore, when he creates a new contact, he can’t see it but other users
can.
I’ve tried to reinstall the backup I had done just before the upgrade and
everything’s working fine. With the backup I did just after the upgrade, the
problem appears.
Some other investigation I made:
I have manually entered the url of a contact in the users session and it
works… he can see the contact details. It’s only the list of contacts that
does not work.
Hope someone can help.
Thanks in advance
Christophe
Free Software Download: Index, Search& Analyze Logs and other IT data in
Real-Time with Splunk. Collect, index and harness all the fast moving IT data
generated by your applications, servers and devices whether physical, virtual
or in the cloud. Deliver compliance at lower cost and gain new business
insights. http://p.sf.net/sfu/splunk-dev2dev
Birgit Becker
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 3147833
mailto: bb@stylite.de
www.stylite.de
Geschäftsführer:
Andre Keller und Ralf Becker
USt-ID: DE214280951
Free Software Download: Index, Search & Analyze Logs and other IT data in
